Estimate My HP?
Old Feb 11, 2005 | 09:07 PM
LAGAININ04's Avatar
Estimate My HP?
Here is what I'm looking to do...
AEM Brute Force Intake (already installed)
4lb Lower Pulley
C&L Upper Plenum
Custom Predator tune by Danny Swanson
Tthinking about an Accufab - more for the throttle response.
Installed a FTVB today.
Do I need a new set of plugs with the set up? Or will a good tune take care of it. Also, what about going up to a 6lb pulley. What is the difference in HP/TQ over the 4 lber.
Am I looking at around 380 hp to the rear wheels? How much torqe?
Thanks In Advance,
Jeff
Old Feb 11, 2005 | 11:21 PM
Suavy's Avatar
You should be able to make the hp you are guessing pretty easy. An up graded set of plugs like NGK TR-6's will work better for you.
As far as the accufab SBTB I could think of many better ways to spend 300 buck. The gains are small with your mods using that SBTB.
A good tuner will bring your set up to life!
Suavy
Old Feb 11, 2005 | 11:49 PM
l-menace's Avatar
you'll be in the 400/500 club or VERY close to it.
Old Feb 12, 2005 | 12:05 PM
LAGAININ04's Avatar
Thanks for the input guys...
This is probably a stupid question but how would you figure out the horsepower at the crank. Lets say if you are making 400 at the wheels?
Jeff
Old Feb 12, 2005 | 02:39 PM
Mr SVT's Avatar
Jeff
I am not sure what the exact % of loss is on our lightnings, however I have always used 20 % for drivetrain loss with an automatic transmission..
only way to truly get that info is to jerk the motor and throw it on a dyno..
