Final Verdict on Brake Pads?
So, I'm searching for new brake pads to go with. I've looked at about every thread in the searches and I still can't decide. Currently I have stock rotors and Napa Ceramix pads.
I'm torn between going back to stock pads, Hawk HPS pads, or another set of Ceramix. The napa pads have lasted a good 25-30K or so. The only reason I was looking at other set of replacement pads is because I think they have warped my rotors. I get an extreme shuddering/vibration when braking.
I am most likely going to puchase those nice new dimpled/slotted rotors from ebay and I'm not sure what pad to go with.
From my searches I've found that:
Hawk HPS - lots of brake dust, squeling noise?
Stock - more noise, not as good stopping power?
Ceramix- minimal brake dust, but warp rotors over time?
Any input would be great or any other alternatives. This is my daily driver, I make it to the track about 5 times a year at most.
Thanks guys,
Jon
Thanks guys,
Jon
The choose is up to you.If you can live with having to wash your wheels when you wash your truck then the hawks are the way to go.but if you just wash the truck and not the wheels
then stay with the ceramix.sTan
Where is the best place/price to get the Hawk pads?
The only place I found them for was $64 for the fronts, $55 for the rears. Is that a pretty good price.
What are some other peoples opions?
Originally posted by Certified Drunk
Stan sell his rotors for $290.00 per set.
http://ruslow.com/Brakes.html
thanks though
Jon
I've recently searched/read every thread for the same reason. I changed to Napa Ceramix at 50k miles, up to 76k now. While there's less wheel cleaning I'm not happy with the brake performance and rotor wear/damage.
I don't recall any brake noise with the stock set of pads, until they wore out.
If it's a daily driver and sees no open track events why should one go with a different friction material than OEM?
