Need lugnut help!
Old Feb 1, 2005 | 03:07 PM
fordlightning76's Avatar
Need lugnut help!
I recently bought used Hoosier Quick Time Pro's 28x12x16 on eagle alloy wheels. I have an 04 L and I was wondering what kind of lugnuts I need to get for these wheels or can I just use the stock ones? If someone can lead me to a part number for summit, jegs, or somewhere else it would be greatly apprieciated!
Old Feb 1, 2005 | 03:42 PM
l-menace's Avatar
NO, you cannot use the stock ones.
The rims will dictate what type of lugnut you need. Most likely it is an ACORN type lugnut.
THere are 3 types of lugnuts that I of:
1. Flat washer type (stock)
2. Acorn (most common)
3. An acorn type with a short hollow tube at the end. (don't know what it is called)
you cannot use flat lugnuts on acorn holes.
Old Feb 1, 2005 | 03:49 PM
Spanky99L's Avatar
you need 14mm open ended acorn lugs
Will
Old Feb 1, 2005 | 09:50 PM
Don's Bolt's Avatar
14mm x 2 pitch acorn style
Old Feb 2, 2005 | 08:18 AM
evo's Avatar
evo
Will
Why do you need open ended? Tech inspect?
