Predator Question?
Old Jan 28, 2005 | 02:45 PM
SILVER2000SVT's Avatar
Predator Question?
This is simple but I haven't been able to find the spark advance parameter in the predator for datalogging. What is this called and what menu is it under?
Or better yet, is there a list out there that describes what all the parameters are?
Old Jan 28, 2005 | 06:39 PM
denny0328's Avatar
Check this file out...
http://www.diablosport.com/downloads...7142_U7158.pdf
It's under 'Real time streaming'
In your predator, you want to go to 'Data Logging', then select 'GAS Acceleration WOT', the timing will be under 'SPARKADV'
-dennis
Old Jan 28, 2005 | 07:35 PM
LightStruck's Avatar
check page 15 of 32 in the previous link......"spark advance" if you want to change it...
Old Jan 28, 2005 | 08:26 PM
-dennis [/B]
I don't have that parameter. Under Gas acceleration WOT the only parameters I have are:
RPM
MAF
MAF V
O2S11
O2S21
Old Jan 28, 2005 | 08:39 PM
Diagnostics>
REAL TIME DATA>
gas acceleration WOT>
show all>
rpm, iat, maf,mafv,spark advance,02s22,02s11,02s21
PS: I also noticed at K-Mart or Wal-Mart the other day, in the electronics stuff, they have a switchable power supply, anywhere from about 1-12 volts, with several different size plugs, for about 10 bucks. This should work great for powering the Predator ( while in the house), the margarita maker, and the pube trimmer, all with one handy device!
Old Jan 28, 2005 | 09:23 PM
I listed above the only parameters that are show under "gas acceleration WOT". Why would the other parameters not show up?
on a whelm I decided to do a "live table reset" and now it won't let me access any of the menus under "real time data" , it gives me a "not compatible with" window.
Old Jan 28, 2005 | 09:40 PM
Yea...mine does now too. After you clear out the table, I guess there's just nothing there to show......have to go log some more......Are you sure when you logged last time, you didn't "choose from list" instead of "show all"---and you just didn't record any spark advance info???
Old Jan 28, 2005 | 09:57 PM
Guys, give me a break on this one, I'm still learning how to use this thing.
I figured it out. This didn't occur to me until I tried to reset it. The last time I did a live table reset was to pull a code off my neighbors superduty...
I reset it with my ignition on and everything looks good.
Old Jan 28, 2005 | 10:02 PM
Hey, I know the feeling!!!!
Glad you got it figured out.
Old Jan 28, 2005 | 10:04 PM
svt4me's Avatar
RPM
MAF
MAF V
O2S11
O2S21
arrow down to se the other paramaters.
