What a stock Predator tune does:
Old Jan 25, 2005 | 05:33 PM
Spanky99L's Avatar
a local lightning owner installed the pulley tune on his truck. He has a 99 with an 8 lb lower and intake. Had engine miss and pinging and knocking at idle. He removed the blower and intercooler and found pieces of cyl 2 rings in the lower intake plenum. i removed his engine this past sat and this is what i found:
Cyl 2 Head
Cyl 2
Cyl 2 piston
more pics coming
Old Jan 25, 2005 | 05:37 PM
Spanky99L's Avatar
cyl 2 Piston Side View:
Cyl 2 Piston Side View
Old Jan 25, 2005 | 05:44 PM
probie's Avatar
TRIM THAT NAIL!
hslightnin's Avatar
it says its for 4 or 6 pounds only when u install it
i wouldnt run it with a 6 #, even with my 4# i had to adjust the timing and fuel table
Old Jan 25, 2005 | 05:45 PM
Spanky99L's Avatar
Head and piston:
Head and Piston:
Piston Top View:
Will
Old Jan 25, 2005 | 05:47 PM
Bob Tompkins's Avatar
WOW
Thats just nasty.
Old Jan 25, 2005 | 05:56 PM
IronmanSTL's Avatar
Sorry to hear about that,
could have been worse.
8lb and non-dyno tune = boom
Hope he gets it back together soon with a better tune
Iron
Old Jan 25, 2005 | 06:25 PM
DX NumNutz's Avatar
Whats the point of this thread? To show how dumb that lightning owner is? He ran an 8# pulley on a STOCK predator tune? Hope you slapped him upside the head when he told you that. Also please trim your nails before the next set of pics.
Old Jan 25, 2005 | 06:27 PM
tallimeca's Avatar
haha
TRIM THAT NAIL!
Old Jan 25, 2005 | 06:36 PM
AZBLACKMONSOON's Avatar
What's intresting is all the other cylinders looked fine, except for some scratches at the very tops of them ,probally from trash circulating,the piston is from #2 cylinder. I was there when Spanky pulled the heads off. I hope Ian get's his motor fixed or new one soon. Best of luck
Old Jan 25, 2005 | 11:10 PM
catchmeonk's Avatar
some guy advised me to use the stock tune with my pullys in the post i started the other day regarding the 90mm mass air sensor for a 2000 L. Makes it scary to know who to trust and who knows what. Im concerned because im getting some pinging at WOT with pullys = 14-15lbs (they were already on my truck when i got it) and the predators pully tune. I just hope its because i need to chang the plugs. i do have 34,000 miles on my truck 28k of which the onwer before me put on and who knows when or if they changed the plugs.
Old Jan 26, 2005 | 03:33 PM
SonicLightning's Avatar
This is kind of like that saying " nitrous doesnt destroy engines, ignorance does" thank goodness I live in florida where the predator tunes were optimized.
Old Jan 26, 2005 | 04:34 PM
20"svt's Avatar
8# on a stock block with a good tune is iffy... but an 8# with the predator tune is just asking for trouble...
hope your buddy has money to fix the engine and to buy a smaller pulley and get it tuned right.
Old Jan 26, 2005 | 07:53 PM
Colorado V10's Avatar
I've got a 2 lb lower and pulley tune and I still had to richen the mixture and I live at 9500 ft! It was dynoed in Denver at 5500 ft, but still lean. Everything else was stock...
I always tell my friends that the dyno tuning (while it can be a few bucks) is always less than buying a new motor.
Old Jan 27, 2005 | 01:42 AM
Blown347Hatch's Avatar
Is the owner a young guy, or relatively new to the high performance? I'm guessing he doesn't know what detonation sounds like.
