Upper Pulley ???'s
Old Jan 12, 2005 | 05:16 PM
whitebolt01's Avatar
Upper Pulley ???'s
I want to buy a ported blower and install a smaller upper pulley. What is the smallest upper pulley that I can run on the stock belt? smallest if I buy a idler setup? How much would each pulley add?
Oh yeah dont want to go with the lower pulley cause of removing it. This way I can just change out blowers.
Thanks,
Simon
Old Jan 12, 2005 | 07:57 PM
NoSuprise's Avatar
Simon, IMHO you really don't want to be changing the upper
pulley. First you need a special pulley removal tool or risk damage to the pulley and the S/C input shaft.
Second the smaller upper pulley will have less grip then the stock pulley.
With a ported blower just use a 6# innerchangable lower pulley, chip and dyno tune.
Changing the stock lower is a piece of cake.
If you think the 6# lower is to much power for your stock block,
just have your tunner hold back the timing untill you ready to unleash that beast.
NoSurprise
Old Jan 12, 2005 | 11:40 PM
LatemodelRacer2's Avatar
get a lower pulley you wont regret
a lower can be swapped in 30-45 minutes from stock to a cageless.
Old Jan 13, 2005 | 05:57 PM
Dork-N-Beans's Avatar
i have a 2# upper from RPM outlet with remove tool was a piece of cake no slip guage goes way past 10
Old Jan 13, 2005 | 06:57 PM
NoSuprise's Avatar
Was the tool purchased or on loan from RPM?
If it was a loaner, you may have trouble getting the tool
the next time you want to change pulleys.
Just thinking out loud.
NoSurprise
Old Jan 13, 2005 | 07:27 PM
Suavy's Avatar
If you don't own a bearing puller you can rent one from lets say Autozone. Thats what I use to change mine out and a screw type bearing press to put it back on.
I had my blower snout turned down so I can run a 2.69 upper.
Suavy
Old Jan 14, 2005 | 07:09 AM
i bought the tool for around 80$ thought i might try a 4# or help someone someday it is a well made tool
