Buying a used FTVB??
Old Jan 15, 2005 | 02:05 PM
MikeO's Avatar
gregg-not only do you have the finest mod i have EVER done to my truck, but you have the best customer service by far!!!!!!! our community should thank you-what you offer is unheard of!!! Mike
Old Jan 15, 2005 | 10:20 PM
fast1's Avatar
Originally posted by Factory_Tech
If there is anything wrong with it, or even if you just want to be sure, send it here and I'll swap you for a new one.
G
Greg, ship it to this address right?
Factory Tech
6818 Midnight Sun Drive
Maineville, OH 45039
Should I put some kind of note or message with it? Thanks again!
Old Jan 16, 2005 | 11:14 AM
BigBobsL's Avatar
Shifts are commanded by the PCM so an early shift cannot really be in the tranny itself. A late shift is often the clutches slipping, but an early has to be a PCM problem.
Hope this helps,
G
Greg, it did help. Pulled PCM and cleaned contact points at service port and it is shifting properly now. Either the contact points were dirty or one of the PCM pins was not making good contact with main harness. Glad I did not have to waste time looking at the tranny. Thanks again for the help.
Old Jan 18, 2005 | 12:57 AM
Factory_Tech's Avatar
Glad I could help!
G
