New rotors/pads going on. Should the dust shields come off?
Get some new Powerslots and Pads put on as well as painting the calipers. While everything is off should I remove the dust shields or keep them on? No "hard core" racing going on but curious if it would be a benefit or hinderance?
Originally posted by Casey02L
Only if you ever want to use them again
They are just
soft aluminum/tin material. I unbolted mine, and cut them
off
They are justsoft aluminum/tin material. I unbolted mine, and cut them
off
Maybe when I rebuild the rear, they can "forget" to put them back.
Originally posted by SVT_KY
I looked at doing that ... The rears really need more air ...
Originally posted by Ruslow
well you can forget part of the rear shield but the hold down
pins for the parking brake shoes use the inner part of the dust
shield for the anchor.sTan
come out in the spring ...
