Whats disadvantage of removing leaf spring
Old Jan 5, 2005 | 05:52 PM
00Bolt's Avatar
I would like to get some drop coils for the front, but if I do that the rear will need dropped more also... I currently have 2" shackles, but would need a little more...
I was thinking of getting JLPs 4" shackles or removing a leaf spring....
can someone chime in on why "not" to remove a leaf spring
Old Jan 5, 2005 | 09:32 PM
redrider02's Avatar
i bought my lowering kit from rousch racing. comes with new coil springs,new leaf springs and new bilstein shocks. for like 650.00
Old Jan 5, 2005 | 10:40 PM
Master Of Pain's Avatar
No more off-roading for you my friend.
Old Jan 5, 2005 | 11:04 PM
Suavy's Avatar
How much of a drop did you get?
Suavy
Old Jan 6, 2005 | 01:37 AM
Red_02_L's Avatar
And where did you get it from???????? i want a roush kit... Fill us in bro.
Old Jan 6, 2005 | 02:29 AM
ShockTherapy's Avatar
Damn, $650 is a smokin deal!
Old Jan 6, 2005 | 08:31 AM
brain bypass's Avatar
Re: Whats disadvantage of removing leaf spring
i would think payload and towing capacity would go down, and handling might be affected as the rear sprigs will have a lower spring rate. just speculation, but it might help on launch by letting the truck squat more, but i don't know about that for sure.
Old Jan 6, 2005 | 08:51 AM
Silver_2000's Avatar
Yeah where did you get that deal ?
Also the Roush kit is for F150's - Since we already have Bilstien shocks are the Roush shocks an improvement ?
Doug
Old Jan 6, 2005 | 11:12 AM
HIHOAG's Avatar
Doug
Yes, the Roush shocks are valved differently. I tried with the stock shocks and then the Roush. Roush were better. I told you already that I tried every combination of stock, shackles, Hotchkis, and Roush.
IMHO the best for the street is:
Roush springs, Roush shocks, Hotchkis sways.
Mark
Old Jan 6, 2005 | 12:28 PM
svt_2004's Avatar
i am currently running 3" rear shackles w/ one leaf removed sits perfect for me
Old Jan 6, 2005 | 12:38 PM
Mark
Mark - As always I appreciate your input - Based on Terrys input about the Roush leafs not towing my boat as well I'll likely just have the stocker rearched and then do the roush up front and then the shocks...
Doug
Old Jan 6, 2005 | 02:36 PM
HIHOAG's Avatar
I forgot about the towing requirement.
Old Jan 6, 2005 | 09:05 PM
Extra300's Avatar
Well if your only choice is between removing a leaf and using 2" shackles
or
4" shackles
Both ways = the handling will suffer, compaired to buying new leaf springs
This is from what i have read.
Really surprised that no one else has posted this
Old Jan 11, 2005 | 07:53 PM
RED 92's Avatar
it will increase axle wrap and wheel hop. If you have traction bars it will squat and go.
Old Jan 11, 2005 | 08:55 PM
Tim Skelton's Avatar
The rather obvious "disadvantage" of lowering the spring rate (which is what leaf removal will do) is to upset the handling. Roush spent much time tuning the L suspension to be sporting, safe, and yet practical.
You will bottom out easier. Your already-understeering suspension will understeer even more. The rear will sway more on turns. The rear shock valving will be mismatched to the new spring rate. Now, you may not find these effects objectionable -- you may even prefer it. And if you live your life 1/4 mile at a time, you probably don't care about any of this anyway.
But if I were you, I would just use shackles (or better yet, get the full Hotchkis or Roush kit). Yes, super-long shackles may allow the axle to move more under the truck under severe cornering, but I bet that 99% of the drivers (myself included) would not be able to detect that increased axle movement on the butt dyno.
