Harley bolts and s/c gaskets
About to paint my supercharger/clean intercooler and was wondering what gaskets will need to be replaced. I have found great info researching just thought I would clarify to make sure so I can go ahead and get the gaskets through ford. Also need to get chrome harley bolts that hold snout to the blower.
Originally posted by FunFord
What color are you going with? By the way I got a JLP Intake, FTVB and Moroso pan you need to see!
Zachary.
Zachary.
You don't need to replace the gaskets. But if you insist, call your local Ford Dealership's Parts department and say you need a Large Lower Blower Gasket and Plenum Gasket. Be sure to let them know the year and model of your truck, there's different bolt patterns for different year trucks. It doesn't hurt to get some Eaton Oil either... XL4 Is what it's called I think.
You cannot buy the supercharger snout bolts directly from Ford without buying the entire blower assembly...I tried. There is an Ace Hardware here in Denver that carries a nice assortment of regular and Allen head bolts that have been chromed. Was looking at them this past Sunday and chrome bolts that are roughly the size of the snout bolts (couldn't remember the exact size when I was there) run about $3.00 each. You might try calling a few Ace Hardwares where you are and see if they carry or can get the chrome bolts for you.
Item Part Number Description
1 6F076 Supercharger and plenum assembly
2 6F089 Vacuum/actuator/valves
3 9H486 Upper intake manifold gasket
4 9424 Intake manifold
5 9J447 Lower intake manifold gasket
6 6K775 Charge air cooler assembly
7 9461 Lower intake manifold gasket
8 9M436 Charge air cooler gasket
Item 3 is the gasket you will need if you wish to replace it. No I dea on the price it is re usable but after every thing else whats 20 bucks?
Suavy
Suavy
There is some useful info here:
http://www.azloc.com/forum/viewthread.php?tid=774
You can reuse the gaskets and the bolts.
Sadf,
I replaced the S/C snout bolts with polished chrome bolts.
I got them from my local Harley Davidson M/C Dealer on special order from Gardner Wescott,.. a major supplier of Chrome & speciality fastners. First the bolts on the S/C snout are Metric. Here's the PN from The Gardner Wescott Catalog:
Bolts: 8MM X 1.25 X 45MM (Length) PN 10778
Washers: 8MM Flat Chrome PN 23989.
They look sweet on the SC! I also Replaced all the upper Plenum bolts as well with polished chrome,............. awsome!
Good Luck
Paul
Good Luck
Paul
Suavy
Suavy
Originally posted by sadf
I plan on cleaning intercooler at the same time, will the lower intake manifold gasket need to be replaced? Also, what bolts need to be replaced?
On the inner cooler thing I sent mine to my local radiator shop and had it cleaned and pressure tested. They charged me 50 bucks. I did this cuz I didn't want to have to tare it back down later and the done one heck of a job cleaning it. I believe they said the boiled it.
