ATTN: ShockTherapy
Old Jan 3, 2005 | 12:17 PM
Extra300's Avatar
ATTN: ShockTherapy
Hi wanted to know if you could help me out with some info on your Grills.. Im pretty sure you said they were the ones on a harley truck, but do you have any part numbers?
I called Ford and with a discount they still wanted about 415 for the 2 pieces.. Not sure if this is right..
thanks
Old Jan 3, 2005 | 12:40 PM
IronmanSTL's Avatar
I believe, I read in a previous post that Shocktherapy uses the stock harley upper grill and uses automotive chrome molding over the stock L grill on the bottom.
His truck looks great and is the grill setup I will use in the spring as well.
I dont think we can use the harley lower.
Old Jan 3, 2005 | 12:55 PM
clonetek's Avatar
The HD lower grill will not fit on a Lightning.
Old Jan 3, 2005 | 02:01 PM
Extra300's Avatar
Ok sounds good. I'm going to order the upper grill now..
If possible it would be very helpful if i knew what and where to get the materials for the lower...
thanks
Old Jan 3, 2005 | 02:19 PM
20"svt's Avatar
you can either do chrome fender molding for the lower or if you want to be able to say that its metal you can get the lower to match from j-jents.
i like to save $$ myself and said screw it and did the upper and lower with chrome fender molding
Old Jan 3, 2005 | 03:00 PM
Nuhklz's Avatar
thanks
Use 3/8" wheel molding for the lower which I bought at Pepboys.
and
Old Jan 3, 2005 | 03:02 PM
Extra300's Avatar
and
Thks
Do you have the harley grill up top or did you do the molding?
Old Jan 3, 2005 | 03:41 PM
Nuhklz's Avatar
Thks
It is all molding.
I was very close to getting a Harley grille but, IMO, this looks cleaner. The HD has 7 cross-members and the stock L has 5.
This isn't bad for $23.
Old Jan 3, 2005 | 03:46 PM
ema100c's Avatar
It is all molding.
Does the wheel molding stick on with adhesive or does it just press on?
Old Jan 3, 2005 | 04:25 PM
20"svt's Avatar
it has 3-M tape on the backside of it, very sticky
Old Jan 3, 2005 | 05:42 PM
IronmanSTL's Avatar
Does any1 have this setup on a Silver L.
I'd really like to see it.
Iron
