non chip reburning mods
It all depends on who did your chip and how aggressive it is. The cheap route is a reburn with a filter, and 4lb pulley
But if you dont want a reburn you could do a throttle body, electric fan, 170 t-stat, intake spacer, JL or PSP intake, FTVB
none of those should warrant a reburn
Originally posted by evo
I don't agree with the FTVB. With the increased line pressure they usually burn in. I think both would be too much. I would think you would need a reburn to back off the line pressure.
the last thing Gregg Evans recommend is INCREASING the line pressure when using his factory tech valve body.
If you want to go faster without reburning the easiest way is.
Electric Fan
Phenolic spacer
CAI
Traction bars
Cat Back with High flow cats.
WEIGHT REDUCTION! (shave a few hundred pounds off it)
Electric Fan
Phenolic spacer
CAI
Traction bars
yes, it free's up some power
do-it-yourself
Thank Soap
https://www.f150online.com/forums/sh...&highlight=fan
do-it-yourself
Thank Soap
