Diablo Predator Tunes
Old Dec 29, 2004 | 12:15 AM
WideOpen03SVT's Avatar
Is there anyone who HASN'T had a problem with the stock tunes in the Predator. I've heard that people have been blowing their engines with the stock Predator tunes and I've heard it A LOT. But I know of a guy close to me who has a stock Predator tune in his 02 L along with an upper and lower pulley swap and he hasn't had any trouble with it after 20,000 miles. I just used a Predator on my dad's diesel and I fell in love with it. I'd like to get one for my truck but am not too sure if I should or not. Any ideas or input? Thanks
Old Dec 29, 2004 | 08:23 AM
Blown347Hatch's Avatar
The Predator tunes are aggressive, but you can pull timing and add fuel with the Predator which should get you by. Mainly, the advantages are:
1. Adjustability (somewhat)
2. No chip to void warranty
3. You can be emailed tunes.
Old Dec 29, 2004 | 02:44 PM
Mr SVT's Avatar
I was also curious. I just installed my predator last night with just the Diablo sport paerformance tune. I did not change any Parameter. Just installed it per instructions. The more I drive it the more it seems that it is making more power, however Can I go back into the tune and adjust the shift points, a/f, etc. I know I would not want to adjust a/f and what not w/o it strapped to a dyno however what about the other settings? or is that just for the other tunes for the pulles, 90mm maf, etc? I do not have a pulley, just a K&N panel filter. I am also up here in the clouds at 5000 ft..
Thanks !
Old Dec 29, 2004 | 04:55 PM
Thanks !
Being at such a high elevation, you probably are (not) lean. The "Performance" tune is the one for you. You could increase and listen for knock. A good baseline for timing at WOT is 16 degrees.
