problem after chip install... HELP
Old Dec 27, 2004 | 07:10 PM
vinnyxgunz's Avatar
just installed my chip and now the car wont start... it will turn and turn and thats it... even when i take out the superchip and just try to run it normally th same thing happens... what am i doing wrong?
Old Dec 27, 2004 | 07:24 PM
chimshady1's Avatar
Iether two things i can think of,1 which lets hope not is that you fried the pcm(did u disconect the battery before installing the chip?then connect it when u were done?)2nd-u might have tripped the vehicle failsafe.Put the key in the passenger door lock and unlock,lock,and unlock again.That will hopefully disable the failsafe.it happened to me when i installed a chip in my f350.same symptoms.Turned over wouldnt start,had me out there for 3 days looking like a fool till my friend came over and showed me the failsafe trick.Good luck ,post back and let me know how u make out.
Jason
Old Dec 27, 2004 | 07:57 PM
BDAZSVT's Avatar
Pull the chip and see if it starts (Disconect the battery first) If it starts clean the terminals better on the pcm. took me awhile to get mine clean I was afraid of messing up the pcm.
Old Dec 27, 2004 | 08:00 PM
chimshady1's Avatar
Hes having the same problem without the chip as well.
Old Dec 27, 2004 | 08:09 PM
vinnyxgunz's Avatar
ha i just forgot to disconnect and reconnect the battery when i was done... thanks guys
