wide band commander installed, question about a/f ratio
Old Dec 20, 2004 | 09:24 PM
got hp's Avatar
It is a really neat gauge and the pc interface it cool but the first thing I did was to find a long stretch of road and nail it. It went to 11.5 a/f ratio and stayed there all the way. My question is, isn't that a bit rich? I was under the impression that 12:1 was the optimum a/f ratio on the L.
By the way the temp was 60 degrees out when I did that run.
Another question is can I alter the tune that Johnny Lightning sent me for my predator (timing and fuel)?
Thanks guys
Old Dec 20, 2004 | 09:31 PM
mlambert's Avatar
11.5:1 sounds great for an off the shelf map, I would be surprised if it was leaner because people would be blowing up their 5.4L's.
I'd imagine that if you're on great fuel you could remove a couple ticks and lean out the mixture.
EDIT: Just noticed you're in El Paso, horrible fuel... I wouldn't go much leaner.
Old Dec 20, 2004 | 09:37 PM
got hp's Avatar
cool, just the info I needed.
Guess I will leave it alone.
Thanks!
Old Dec 20, 2004 | 09:50 PM
chimshady1's Avatar
12.0 is usually what tuners shoot for,but 11.5 is damn close for a mail ordered tune.
Old Dec 20, 2004 | 10:06 PM
mlambert's Avatar
Thanks!
If you watch EGT's you could probably remove some fuel, just be vigilant of IAT and outside air temps as well.
Old Dec 20, 2004 | 10:09 PM
got hp's Avatar
what would be optimum EGT temps? I have never used one of those gauges before.
Old Dec 20, 2004 | 10:13 PM
St Louis Lightning's Avatar
Isn't tailpipe sniffers always higher? So 11.5 pre-cat is closer to the 11.8 - 12 you see a lot of guys posting from dyno's that use tailpipe sniffers.
Old Dec 20, 2004 | 10:19 PM
mlambert's Avatar
I wouldn't trust a post-cat a/f gauge, always weld in a bung and use that to check your ratio.
I have no idea what the best EGT is for an L but I'm sure that info could be found with a quick search on here. I'll know as soon as I install mine though
