Magnum Powers Idler Bracket
PSP is pleased to announce that we've now got the Magnum Powers Idler brackets available. This is a replacement for the entire stock blower belt tensioner bracket. You swap your tensioner and exisiting two idler pulleys onto this, and then using a 3rd pulley on the adjustable tensioner, you can preload the belt. In addition to the added preload, it also gives the belt much more wrap, which is perfect for those running small upper pulleys like 2.7s. We'll be doing our own testing on a local truck, but Charles at MP has already seen big performance from it. On his own truck, he went from 14 psi to 17 psi just adding this new piece!
The brackets are $259 and we can supply you with the extra pulley if you need it.
Originally posted by l-menace
I take it that this unit will work with ANY blower?
Eaton, MP, KB?
Eaton, MP, KB?
I'd like to see an actual test done showing that these things work!! Looks like a wonderful piece, but I would like to see a before and after dyno and boost graph!!!
And Sal is just the man to prove it to us!!!!
Hook us up Sally!!
Hook us up Sally!!
Originally posted by Casey02L
Curious; how is it adjustable?
Suavy
Thanks Suavy for posting the pic! The adjustable stud inserts from the back into a slot that is machined in the aluminum casting and is locked in place by the washer and nut you can see in the picture Suavy posted. The pulley mounts on the adjustable stud just like the other pulleys mount on the bracket. If the upper idler is adjusted close up under the blower pulley belt wrap is increased by 45 to 50 degrees. I'll send Suavy a picture of the MP Pulley Bracket mounted in the L so you can see the results.
Charles
Charles
Originally posted by Suavy
Here you go Charles
Here you go Charles
Here's a question?Can it be made to actually control boost from 14 to 17 with adjustment.Sreet/strip kind of?
Awesome product Charles, I've heard a lot about it, and now that I see it, and can understand AND SEE how it gives so much more Belt Wrap, I LOVE IT
AND WANT ONE, I see my bill is just going to get higher and higer and higher (as I get faster faster and faster....................
WOO HOO.............
