Turbo L
Old Dec 14, 2004 | 01:25 PM
badasstruck1's Avatar
Turbo L
Well here is the deal I blew another motor well not really it appears that the factory chain tensioner on the cams gave away ate up my oil pump. So I am done with the supercharged L I am now having a 88 mm turbo motor built. Manley rods Je .020 pistons CNC ported heads, custom grind turbo cams and custom built intake By Me! Looking for the magic 800 hp 1000 ft# of tq But now I am scared that the manley Rods will not hold together are there any other options out there besides Carillo?
Old Dec 14, 2004 | 01:40 PM
Silver-Bolt's Avatar
Carillo is the way to go. Thats the rod Ford used in the last Cobra-R (5.4L).
Old Dec 14, 2004 | 01:43 PM
TimBurntire's Avatar
Manley also makes a forged I-Beam rod that will hold up to 1000hp. I have these in my stroker race motor.
Old Dec 14, 2004 | 02:06 PM
Blown347Hatch's Avatar
My understanding was they were Manley H-Beam?
Old Dec 14, 2004 | 02:54 PM
Tim Skelton's Avatar
SVT Mustang Cobra R
Specifications
GENERAL
Vehicle configuration Front engine, rear drive two-door, two-pass. coupe
Engine type V-8, DOHC, 4 valves/cyl.
Displacement, ci/cc 330.1/5409
Engine modifications Carillo connecting rods, forged pistons, McLeod aluminum flywheel, higher-flow aluminum cylinder heads, Cobra 5.4-liter intake/exhaust cams, tubular-steel exhaust headers, low-restriction two-piece Cobra 5.4 intake manifold, higher-flow single-bore 80mm throttle body, K&N air filter
Horsepower, hp @ rpm, SAE net 385 @ 5700
Torque, lb-ft @ rpm, SAE net 385 @ 4500
Transmission type 6-speed manual
Tires/wheels BFGoodrich g-Force KD 265/40ZR18/18x19.5 forged aluminum alloy
Other modifications Fuel cell, front splitter air dam, rear-deck spoiler, power-dome hood, Brembo four-piston front calipers, Eibach springs, induction-hardened halfshafts, 3.55 rear axle, T-56 Tremec six-speed manual, Borla mufflers
Old Dec 14, 2004 | 05:08 PM
We were planning on the I beams but 800 hp at the rear wheels is pushing the 1000 hp limit so I am not real happy with that either.
Old Dec 14, 2004 | 06:05 PM
MISTERgadget's Avatar
there are alot of options, do some research on places other than f150online and nloc and you will find alot.
Old Dec 14, 2004 | 06:32 PM
racetested's Avatar
I believe Sal at PSP has a 1200hp set-up, so you might want to give him a call for help.
Old Dec 14, 2004 | 07:33 PM
Originally posted by Tim Skelton
SVT Mustang Cobra R
Specifications
GENERAL
I was referring to the regular Cobra of today, not the "R".
Old Dec 14, 2004 | 08:06 PM
svtguy12's Avatar
You need billet rods.
Tony
Old Dec 14, 2004 | 08:09 PM
DL's Avatar
DL
Old Dec 14, 2004 | 09:28 PM
Bad as L's Avatar
I run Olivers...the only other thing I would consider is something made out of 300M.
Old Dec 14, 2004 | 11:32 PM
The 300M rods that mihovetz and some of the other guys run are uber-pimp.
Old Dec 14, 2004 | 11:34 PM
cpeapea's Avatar
Oliver and Carillo are definitly top notch and expensive. ive also heard great things on Pauter rods.
Old Dec 14, 2004 | 11:58 PM
red gen 1 94's Avatar
Dont do it. I hear turbo wont work on a Lightning
