Pinion Angle
Old Dec 13, 2004 | 05:31 PM
whitebolt01's Avatar
Pinion Angle
I posted this a month or 2 back
https://www.f150online.com/forums/sh...t=pinion+angle
Well i got the angle finder measured the angle was 0 at tranny and 5.5 at the rearend. I then got the shims removed, measured angle and it is 2 at tranny and 5.4 at rearend so that would make a 3.4 degree angle right? is that the right angle?
Thanks,
Simon
Old Dec 13, 2004 | 10:30 PM
Ruslow's Avatar
NOPE! that is the the amount that you are still off!!.the 2 angles are to cancel each other out.You did not say if if they are neg of pos angles either.sTan
Old Dec 14, 2004 | 12:56 AM
Negative. So I am still off 3.4 degrees?
What do I need to do?
Old Dec 14, 2004 | 12:25 PM
ttt, guys I need to know if the angle is off.
Old Dec 14, 2004 | 02:10 PM
Ruslow's Avatar
you need to have the angles cancell out.So if you are neg on one end and pos on the other then the diff is the driveshaft angle.I could care less what each angle is individually it is what they total that is important!Stan
Old Dec 14, 2004 | 02:34 PM
they total -3.4 degrees. So what size shims do I need?
Old Dec 14, 2004 | 04:22 PM
ttt
Old Dec 14, 2004 | 06:50 PM
bump
Old Dec 14, 2004 | 08:40 PM
lightning66's Avatar
Isnt 3 to 4* neg what you want? That is what my understanding is. He should be in that range.
I take it you have an 03-04 with the shim, I simply flipped mine with the 2"drop in the rear and put me what I understand to be ideal 3 to 4 * neg. No driveline vibe with my set-up.
Old Dec 14, 2004 | 08:41 PM
I take it you have an 03-04 with the shim, I simply flipped mine with the 2"drop in the rear and put me what I understand to be ideal in the 3 to 4 * neg range. No driveline vibe with my set-up.
Old Dec 14, 2004 | 11:19 PM
Cool yeah I have an 04. I have the 4 inch dorp shackles from JLP and removed the shims. So I figured the angle and I guess I am fine.
