DEBATING ON TR"6 OR DENSO 22"s FOR MY JDM ENGINE
Old Dec 13, 2004 | 03:53 PM
tlfwatch's Avatar
Question DEBATING ON TR"6 OR DENSO 22"s FOR MY JDM ENGINE
Hey lightning friends chime in here give me your thoughts on these two plugs TR6"s or denso 22"S for my JDM built motor and what about our stock water pumps is our stock water pumps sufficent and if not who makes one that is non electric high preformance pump????? thanks lightning friends for your input
TOM
LIGHTNING FAST
Old Dec 13, 2004 | 04:56 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
plug choice is dependant mostly on what amount of boost you're throwing at the motor.
A 2003 Ford Factory water pump provides good cooling. Don't buy the hype of the 'Cobra R' being better. In short, it is not.
Bob
Old Dec 13, 2004 | 05:04 PM
B-Man's Avatar
Cool
I recently installed the Denso IT-22's in my L, when I installed my 4 lb. lower.
Great idle, runs perfect at any RPM or speed.
However, Sal told me in an e-mail that the TR-6's will withstand more "abuse" if you run big boost, nitrous, etc.
I'll go out on a limb and say both will probably meet your needs.
JDM will give you good advice I'm sure.
Old Dec 13, 2004 | 05:20 PM
Bob Tompkins's Avatar
TR6's work just fine and they are available locally for a $1.50 each. I used the denso's in my Supra with great results but all my blown Fords have had TR6's.
Make sure your gap them correctly, add a little anti seize and torque them correctly and you should be good to go.
Bob
Old Dec 13, 2004 | 05:26 PM
eposey's Avatar
I have the TR6ix's, the iridium model and am having no problems.
Old Dec 13, 2004 | 06:03 PM
monkeysL's Avatar
Bob
JUST SAY NO TO ANTI SEIZE UNLESS U HAVE THE EXTRA THREADS, anti seize causes them to wanna blow out more easily...its almost like it lubs thems
Old Dec 13, 2004 | 06:06 PM
JimIII@jdm's Avatar
Former Sponsor
Tom,
Hey bud I sent something to ya today, it went to the shop!! (not the motor just yet )
We want to see NGK TR 6's in it gapped at a tight .034"
Talk to you soon
JimIII
Old Dec 13, 2004 | 06:09 PM
chimshady1's Avatar
Go with the NGKs.In my opinion ,especially for the money the Densos are crapola!I just pulled mine after 1000 miles due tue a miss and found 4 out of 8 with broken ceramics.Keep in mind i was dyno tuned and had a great air fuel.They just didnt take well to my high boost 8lb lower and 2.7 upper.
Old Dec 13, 2004 | 06:15 PM
tallimeca's Avatar
hmmm
if i was buying a motor from someone.......i would go on their recommendations.......but that's me.
Speaking of me........i have ngk TR6's gapped at .038 on my 4lb lower...
Old Dec 13, 2004 | 06:59 PM
tlfwatch's Avatar
Smile THANKS JIM MAN I CAN HARDLY WAIT"
Originally posted by JimIII@jdm
Tom,
Talk to you soon
JimIII
"thanks jim i know what it was?? hope you got a list of all my mods i sent in i think with your motor [JDM] i will be able to blow away anything that comes my way. If you say TR 6"S then thats what it will be. ????5-20 motorcraft first 3000 miles and after that 0-20 mobil 1no high boost till after first 1000 miles correct. :santa:
LIGHTNING FAST
POWERED BY JDM
Old Dec 13, 2004 | 07:56 PM
LIGHTNINROD's Avatar
My NGK BR7EFs(5lb pulley) have been in for over 30,000 miles in my 01 L. I used Lubro Moly's antisieze and ran them down finger-tight plus 1/16th of a turn more. Over-torquing plugs in our 'soft', 4-5 threads, aluminum heads causes more blown plugs than a quality antisieze---with the proper torque/tightening.
Dan
Old Dec 13, 2004 | 09:32 PM
lightning66's Avatar
Same here with no problems but plan on changing them more frequently
Old Dec 13, 2004 | 10:54 PM
Woodys2000's Avatar
I run TR6s as well @ .038.
Old Dec 13, 2004 | 11:43 PM
blackbeast 99's Avatar
Plugs
I used NGK TR6 in the past. They worked well for my needs. I now use Denso and I do not have any problems yet.... You can't go wrong with either brand.
Old Dec 14, 2004 | 08:17 AM
Don's Bolt's Avatar
I run TR6's in my JDM motor
