Do KB blowers still lock up?
Old Dec 12, 2004 | 08:03 PM
NTIMD8's Avatar
Or was this a problem with the early ones only and has since been fixed?
Thanks, Jason
Old Dec 12, 2004 | 09:04 PM
JeffsLightning's Avatar
This should help.. A few names should look familiar....
http://www.modularfords.com/forums/s...ad.php?t=19143
Old Dec 12, 2004 | 11:49 PM
Bad as L's Avatar
I had a theory that the intake manifold wasn't flat and was distorting the blower case. The reason I thought that was because I had to remachine my own manifold and it was not flat by a bunch.
I tried explaining that over on that site and the thread got locked. I think JJ complained to the Mod and had it shut down because I was not agreeing with him. Or maybe it had something to do with KB being a SV.... Whatever....I thought it was good information for everybody but somebody didn't think so.
Dale
Old Dec 12, 2004 | 11:59 PM
Casey02L's Avatar
I've wondered if it was people not tightening the upper intake down right, and distorting the case. I know I have seen this problem once with an Eaton.
Old Dec 13, 2004 | 07:20 AM
KB ZILLA's Avatar
I have about 10,000 miles on my KB with no problems
Old Dec 13, 2004 | 10:07 AM
99svtlightning's Avatar
There were a few that locked up in the prototype stages, but that was fixed a long time ago. The issues were due to clearance of the rotors and the casing. There were a lot of factors like the blowers being torqued wrong, intakes not exactly true, etc. To get around all of these issues, KB changed a few things(more forgiving) and all has been well since.
Old Dec 13, 2004 | 11:48 AM
easterisland's Avatar
Nick had to return his more than a few times and they finally gave him his money back.
Old Dec 13, 2004 | 02:04 PM
CHIKIN1's Avatar
Mine locked up a couple of months ago. KB treated me right on it though...no complaints here!!!
Old Dec 13, 2004 | 02:59 PM
DL's Avatar
DL
Hey Easter,
Nick is on his 9 th blower. KB has been great about replacing them with new ones. If the 9th blower doesn't hold up, then Nick's is getting his money back.
Old Dec 13, 2004 | 03:06 PM
Originally posted by DL
Hey Easter,
That is what I get for listening to second hand info...
Old Dec 13, 2004 | 03:12 PM
dealerjim's Avatar
Got a little over 20k on mine with no problems. (knock on wood)
Old Dec 13, 2004 | 03:33 PM
Mine had around 20K when it started making a noise. KB warrantied it and I sold the new one they sent me back. Then the little ebay thief sold it several more times.
Old Dec 13, 2004 | 03:47 PM
Big Man's Avatar
So what do you have on your truck now if you don't have the KB no more?
Old Dec 13, 2004 | 04:02 PM
stock eaton
Old Dec 13, 2004 | 04:15 PM
Suavy's Avatar
From KC@KB...
Our investigation indicates the only ones that ever came back were ones that ran "hot air" filters (exposed under hood filters). We have a lot of them out there running perfectly that are from the first production run on those trucks using true cold air kits.
All the ones that ever came back were damaged at the point of entry where the bypass valve feeds air back into the inlet. Temperatures under the hood can exceed 200 deg F and when mixed with the bypassed air, this can exceed the maximum temperature threshold for the rotors. From our analysis so far, this appears not to be a rotor-to-case clearance issue or rotor-to-rotor clearance issue, it is a hot air temperature issue.
When any supercharger is run at very high boost levels, this becomes extremely critical, so DON'T RUN OPEN ELEMENT FILTERS BECAUSE YOU THINK THEY "FLOW MORE". Not much air flows on a locked up supercharger! Why do ALL the OEM's spend millions on encasing their filters and drawing air from outside the engine compartment?
BTW: We appreciate your concern. We as concerned as you if not more. All indicators so far are temperature related, so that is where we want everyone to concentrate. If you are running an exposed filter, get rid of it and install a cold air kit right away.
If we can get a Lightning guy to come by Kenne Bell, we will look into designing and offering a true cold air kit ourselves. We ran a bunch of tests on the factory fenderwell intake, and it was restrictive at high boost levels, so we understand why some are choosing to go with hi-flow filters, but you must find a way to get the air from outside the engine compartment - this will help save your supercharger from damage.
From everyone at Kenne Bell, have a safe holiday.
