Truck shuts off at WOT..help!?
Ok my 2000 L has run great for 4 years. I have a 4lb pulley, a chip, and a filter. I recently had the Eaton ported by Apten and have not had it retuned yet. Twice since the porting my truck has shut off at WOT. No stumbling, no hesitation, I mean it literally shuts off. It has done it once at the strip and once on the street. After I pull over (sans power steering and brakes
) I can put it in park and he starts right back up. What is up with that? Could it be so lean that it would shut off? Is it maybe a spark plug gap issue? I have Denso's that are gapped at whatever was recommended for the 4lb pulley. All comments welcome. Thanks!
Originally posted by SLVRLTNG
Is your chip taped in good and tight?? Could have a bad connection at WOT.............
Make sure you have OVER a quarter tank of gas at ALL times when racing or playing around on the street....Actually my truck needs atleast 1/2 tank....I have experienced the SAME problem, but NEVER with 1/2 tank of gas....
Give it a try and let us know!!!
Had the exact same thing happen to me and my 01 L and that will scare the 'poop' out of you! It was the chip. It was NOT loose. It 's contacts had too little 'clamping power' You need a new chip.
Dan
Dan
If the contacts on the chip itself look contaminated you may want to take a pencil eraser and "Shine them up". The best thing for better contact is to have someone that can solder, tin the pins. This will give a shiny look and provide a good electrical connection. Plus it will slightly thicken the pins for better connection/insertion.
I do some automotive module repair, and find that poor, tarnished, or cold solder joints is the top issue.
Lew
Lew
