03 L problem
Old Nov 30, 2004 | 10:23 AM
OD1010's Avatar
03 L problem
Hey guys i was driving home the other night it was somewhat cold out (high 40s) and when i started to accelerate i noticed a strange rumbling noise, so i immediately let up on the gas. When i did my RPMs went way down and if felt like it downshifted. The next day it was gone and ran perfect. Any ideas what it could have been? I was thinking maybe the cold weather but im not sure. The only mod i have right now is an intake. thanks!
Old Nov 30, 2004 | 10:31 AM
LIGHTNINROD's Avatar
Could it be described as sounding like "marbles in a can"? If so, you were hearing the dreaded winter-detonation sound. It can break the engine apart so I'm glad you backed out of it.
Dan
Old Nov 30, 2004 | 10:35 AM
OD1010's Avatar
not so much sounding like marbles ina can but a rumbling like the whole truck was vibrating from the rumble. but just in case....what is winter detonation?
Old Nov 30, 2004 | 01:06 PM
Frank S's Avatar
You probably got some bad gas if it is running fine now.
Old Dec 1, 2004 | 12:59 AM
OD1010's Avatar
now that i think about it, i did get gas at an unusual place. i normally get gas at at one or two place but i was running low so i got it at the closest place; and it was a cheap gas station. if that was the problem, i still dont know what "winter detonation" is. if anyone can answer please do! thanks. ~Matt
Old Dec 1, 2004 | 01:43 AM
JL12345's Avatar
my guess on winter detonation would be: colder air has more oxygen, so in a way it would lean out the a/f mix. i'd figure the computer could adjust though. also the lower temp of the air should help the a/f mix resist detonation as well. but who knows..
Old Dec 1, 2004 | 08:20 AM
ByByBird's Avatar
Yes you MAF will compinsate for a certain amount of temp and volume difference. Cold air does not help a heathly A/F. It will ALLWAYS lean out the mixture. If your Border line lean on your A/F a nice cold night will push it over the edge.
Cheap gas ( lower quality, Lower octane, Oxygenated gas ) can and will cause knock on a L and any other vehicle made to run on 91+.
The lower the octane gas = Faster burn rate.
The Higher octane = Slower burn rate.
Lower oct gas will "pre ignite" before spark is set to it and create a flame front. Then when the spark ignites it creates a second flame front on the remaining fuel. When the 2 flame fronts meet it creates a VIOlENT crash between the two of them causing piston and rings to shake and unnatural stress on the rods and bearings. That is what knock is and I hope it help you out.
I left out why high timing causes knock. Same thing as above except you know firing the cylinder off sooner trying to take advantage of a complete burn. Low octane gas will burn to fast once lite. Higher octane gas will allow a slower more controlled full burn with out causing an "crash" in the cylinder.
I hope most of this make sense and it been a while since I studied up on this stuff. I should be 99% correct on this topic.
Old Dec 1, 2004 | 01:48 PM
JL12345's Avatar
i agree with most of that, except where it comes to the burn rate part. the notion that a higher octane fuel has a slower burn rate, is true in some instances but not in others. from the research i've done, there are quite a few ways for chemical engineers to raise the octane of a fuel, some result in a slower burn rate, but some do not.
also if you could some how have colder air w/ the same # of oxygen atoms in it enter the engine, that would help fend of detonation, but that'd be impossible on the street.
Old Dec 1, 2004 | 06:58 PM
ByByBird's Avatar
Thank you for putting icing on my cake
