Eibach Hangers
Old Nov 27, 2004 | 09:59 PM
sadf's Avatar
Eibach Hangers
I was wondering if I could use Eibach Hanger Hardware with my Ground Force Shackle. I work for AutoZone and in about a week I will be able to get 30% off ordered parts for that week only. In the Eibach catalog it is listed as Hanger Hardware, it retails for like $160.00, and it supposed to be good for 3 inches, which would give me an estimated 5 in drop in the rear. I then would like to use Western Chassis A-arms up front and some good shocks all around. I guess I just need to know if the Eibach Hanger Kit will work with my Ground Force kit and give me a good 4-5 in drop.
Old Nov 28, 2004 | 12:36 AM
FunFord's Avatar
Registered User
Blake-long time no see!
Old Nov 28, 2004 | 12:52 AM
Ron Rairie's Avatar
Yes. You'll be able to slam the crap out of your L. by using the drop shackles inconjuction w/ Eibach hangers
Old Nov 28, 2004 | 09:20 AM
Eds 01 Lightnin's Avatar
SADF, I just recently received the DJM Hanger/Shackle Kit (170.00) but have decided to only use the shackles for the 2" drop. The hanger/hardware are new in the box and I will sell them to you for a bargain. Make me an offer if interested. I'm in the Conyers area.
Ed
Old Nov 28, 2004 | 09:51 AM
svt_2004's Avatar
hangers are a pretty difficult install! I have a set which i decided not to use, i removed leafs instead! So if u need a set let me know, or if you have any questions about removing leafs then i can help
Old Nov 29, 2004 | 09:04 AM
sadf's Avatar
I was advised in an earlier post to just remove a leaf. I would assume that is worth only an inch and the rear as is already sits higher than the front. I need to get about 2 in out of the back because thats how much more the the front will be with the a-arms installed. How much for the DJM hangers?
Old Nov 29, 2004 | 09:46 AM
svt_2004's Avatar
remove second leaf and add a 2 inch shavckle, that should fix it
Old Nov 29, 2004 | 04:22 PM
Krix330cic(NJ)'s Avatar
^^^ can you type out a quick DIY on the leaf removale?
Old Nov 29, 2004 | 07:21 PM
sadf's Avatar
I already have the Ground Force kit, which is about 1" up front and 2 " out back. The back has got a good rake to it. Im going to go 2" more up front with WC A-arms. Think that just removing a leaf will look all right, or will that be to little. I think that a leaf would only take out an inch out back and with the a-arms I would have the over all equivilant of like a 3/3 " drop, right?
