Steering wheel lights
Old Nov 20, 2004 | 11:17 AM
jimkalfakis's Avatar
Does anyone know how to change these things. Mine went out on the right side. Can the switch cover be removed or do I have to take out the friggin airbag?
Old Nov 20, 2004 | 12:20 PM
thepawn's Avatar
they are surface mount LEDs....you have to replace the whole switch.
Old Nov 20, 2004 | 02:33 PM
DAMN IT!
Okay, how do you change the switch?
Old Nov 20, 2004 | 10:52 PM
Mondo1's Avatar
The switch and the bulb can be removed...and yes you must remove the airbag with the 4 screws behind the steering wheel.Its easy.(I went throught this) Then the switch can be pulled out.Do this carefully it will be a bit stubborn at first but if you jiggle it , it will pull out.Putting it back will require you to first push in the rubber switch cover and then push the assembly back in and whille holding it , snap the connector back in. Replace the airbag and you should be good to go.Enjoy!
Old Nov 20, 2004 | 11:48 PM
lifeguardjoe's Avatar
Don't forget to disconnect the battery!:santa:
Old Nov 21, 2004 | 01:00 PM
Guys, thank you so much
