Vibration in 2nd Gear?????
Old Nov 19, 2004 | 05:04 PM
EastcoastEnt's Avatar
does anyone know what could be causing a vibration in 2nd gear at about 20 mph..
It only seems to be vibrating in 2nd at around that speed.
the truck is a 2004 lowered front and 2"in the back, but i dont think this has anything to do with it, because i noticed it afterwards.
thanks for the help
Old Nov 19, 2004 | 05:12 PM
ByByBird's Avatar
Re: Vibration in 2nd Gear?????
thanks for the help
Mine also vibrated after I droped the rear 2"s. Mine truck is an 03 so I removed the stock shims and all is well now!!
Old Nov 19, 2004 | 05:15 PM
well, i was thinking that it might be the drop but if this was the case why wouldnt it vibrate in all the gears?
Old Dec 2, 2004 | 11:56 AM
Superscrewd's Avatar
guys I also have a vibration around 20-25 mile per hour. My truck is an 04 Screw 2WD, raised 2.5 in the front, 2 inches in the back. I was wondering if the change in driveline angle may be the culprit. Do I need to have shims installed? I have the two piece driveshaft and 3.73 rear end with LS. I started to notice this after the lift was installed, it has been hard to isolate and its smooth as glass at highway speeds.
Old Dec 2, 2004 | 10:59 PM
freddytran's Avatar
Superscrewd,
Would you mind emailing me at freddytran@yahoo.com? I have a question as to what the Ford rear blocks look like. I am planning to buy some off another member but want to make sure I get the right ones. I want to send you a pic of the blocks he is offering. Thanx.
