new 15" wheel found!
While searching for new rims for my foxbody, I stumbled across a a Weld ProStar knockoff by Prime Wheels in our bolt pattern.
15x7, 15x8.5, 15x10, 15x12.5!! I believe I will be trying these out over the winter. I hope they fit after grinding.
edit: just did a quick search, found them for $169 each on first try!!!
Just because they are 15 inch and the same bolt pattern, doesn't meen they will work. The Bogarts are custom made with very thin hoops, and still require a ton of modification. These may be better or may be a real pain. We have to get some measurements
Edit
I just called them, and they don't make them in out bolt pattern anymore
Edit
Have you checked these? Last time you asked about rims somebody mentioned these.
http://www.diamondracingwheels.com/AvengerSeries.htm
