Who has instructions or a speed guide for installing JL 58" traction bars?
I just purchased a set of JL 58" bars from the classifieds, now I humbly request a little help from the experienced to mount these bad-boys. Geez, these control arms are long. Installed, would this be considered a 4 link suspension setup? I'm also worried about the side to side (lateral) movement of the axle and if that meandering will stress the necks of the bars near the eyelets. I think it's time to call Ruslow for a Panhard to add to the setup.
Thanks in advance!
Thanks in advance!
I have the Instuctions that came with mine if you want i will make a copy and send them to you. The thing you must remember is that the ft mounts should point backwards toward the rear axle, the rest is quite straight foward if you need info you can e-mail me and i will try to help. Bart
I have the instructions here somewhere too. If you need I can scan them and email them to you. At least I think I can do that.
I have the JL's and the FRPP lowering kit. The rear feels VERY solid.
