Bogarts + Stock lug nuts?
Old Nov 12, 2004 | 10:33 PM
Casey02L's Avatar
Is everyone using stock lug nuts, or acorn style lug nuts with your Bogarts? Looks like you can run either.
Also, they say racing use only; how fragil are they? I mean will they take a trip down the road for a few miles so long as you don't hit any pot holes?
Old Nov 12, 2004 | 10:36 PM
Don's Bolt's Avatar
With mine you have to use acorn lug nuts
I drove around Atlanta a little bit with my bogarts while I was at FFW down there. So as long as your carefull you should be OK. Just don't do any high speed cornering.
Old Nov 12, 2004 | 10:57 PM
Casey02L's Avatar
Old Nov 12, 2004 | 11:13 PM
Don's Bolt's Avatar
Do you have Tapered inserts on your rims??
if so use the acorn lug nuts
Old Nov 12, 2004 | 11:50 PM
Casey02L's Avatar
They have a tapered insert,a nd a flat area that fits the stock lug nut. The taper seems like it would center the wheel better.
