Full Exhaust Or Hotchkis
Title is pretty self explanitory. I decided I am more than likely keepin my truck, so I'm debating what my next mod will be. I've decided that this winter I'm getting either the Hotchkis TV w/ 4 QA-1 adjs. or the Dynatech LTs and Mids. Now After install and everything I believe they are pretty even mods cost wise. I just cant decide which one to go with. If you guys had to pick one which is it ??
Also Question for those out there with the Hotchkis TVS, does the installation of this kit affect launching at the track be it better or worse ??
Thanks Guys.
Thanks Guys.
Decided how you want to go fast. If you want to go fast around corners get the suspension, if you want to go fast straight line and make a lot of noise get the exhaust.
BTW; just Hotchkis sway bars make a big difference in the trucks
Originally posted by ShockTherapy
Get the exhaust, and save some $$$ for the Roush suspension.
Caasey, the problem is I like to do both quite abit...not so much road course, but here in ny we do have some twistie roads that are fun to take a little above the posted limit. LOL
I felt the Hotchkis kit was a great addition to my ride.
It launched much better than stock. However, with the JLP traction bars AND the Hotchkis TVS kit, the truck launches pretty darn good. I'm happy with it. Also on the turns, it feels so much more controlled. Even if I went to the track every other weekend, that's still 5% of the time that it would be going straight alone. The other 95% of the time, is why you want the suspension.
Though a full exhaust would be sweet!
Get both!
Get both!
Originally posted by Blown5Pnt4
I cant get the roush suspension because of how it cuts payload, I do use my truck for truck stuff sometimes...
In sum, I see no real difference between payload capacities of the Hotchkis and Roush systems.
I like the Hotchkis, but if I had to do it all over again, I would probably get the Roush.
In either event, just install some helper airbags ($200) and you have all the payload capacity that you need.
Re: Full Exhaust Or Hotchkis
Originally posted by Blown5Pnt4 If you guys had to pick one which is it ??
I think the Hotchkis sits nice - it's not too low. I use mine with the Hotchkis springs front and rear every day and I've hauled several hundred pounds without bottoming out. The latest was a 15KW generator and some supplies put in with a fork lift. Before that, somewhere around a 10-12 bags of Quikcrete. It sagged with the concrete but didn't bottom out.
