Need Help Intercooler Pump...
Not working even with a manual switch. But if you connect power directly right on the connector right before the pump it will work. Fuse looks good and relay I don't know. Is there any other possibilities if the relay is good???
I assume you live in AZ? If so, I would check the relay. If you live where it is cold, then that may explain it too. The pumps are not supposed to go if the ambient temp is under 40 degrees.
Well finally figured it out by accident. Messy with the connector the + wire fell out. Faulty connector I can put the wire back in and it works but it won't stay. Going to the dealership today. Thanks to all who replied. Checked everything like three times over pulling my hair out and it ended up something stupid like this. Just my luck....
