Service Engine Soon
Old Nov 6, 2004 | 09:15 AM
SMOKINTRUCK#1's Avatar
Service Engine Soon
What will keep giving me this light service engine soon ? It happens at boost/WOT periodicaly. I clean throttlebody with carb cleaner and reset it goes off til next WOT. Thanx! for any info.
Old Nov 6, 2004 | 10:49 AM
Grimace's Avatar
Check all your vaccum lines. You may have had one get loose or cracked and wfo causes a leak which throws a light.
Old Nov 6, 2004 | 11:30 AM
MaxTorque02's Avatar
Re: Service Engine Soon
First thing you need to do is get to an Autozone and have your code read. Without knowing what code it's a stab in the dark. Post the code number on here and somebody should be able to offer you some areas to look at.
Old Nov 6, 2004 | 10:57 PM
porsen's Avatar
Choice of gasoline?
Could be your gasoline brand!
I tried Costco's 93 oct. twice and both times did the Check Engine Light come on at boost. With i.e. Amoco's 93 it's fine
Old Nov 7, 2004 | 01:04 AM
ND4SPD's Avatar
have you dissconnected the batt so see if it will erase it...if you have than I would do what MaxTorque02 said.
Old Nov 7, 2004 | 08:09 AM
THANX! for info, it has been doing this since Iput the K&N panel in and stock. I know it throws a little oil new even with pre-oiled ones. But thanx I'll will get to the Zone since a new one opened about a mile from me.
Old Nov 7, 2004 | 10:50 AM
Redlightn 02's Avatar
Make sure you connected your maf connections back up when you changed the filter.
Old Nov 8, 2004 | 06:13 PM
Re: Re: Service Engine Soon
Thanx !went to the zone and got a PO125 code it stated low coolant temp (160)thermostat in their now also fuel presure low or loop stuff. thats a generic scan tool but, after that he cleared it. so I'm good to next WOT I guess.I know their was some trucks had problems with fuel pumps well see if I need a new Walpro pump in future. Maybe a tuner will chime in this thread.
