Whats the most timing u can run?
On 100 octane and a good dyno tune.I made 476 h.p. on my last dyno.I just added a 2.7 upper to my already had 8 lb lower.I'm running 22 degrees timing on my race program .I really would like to see 500h.p. My upper before at 476 was stock.Has anyone safely run 24 degrees?
Jason
Jason
More timing is not always a good thing on mod motors. Too much timing and you will lose power. Most race tunes on the L using hi octane fuel are in the 18-22 range at wot. Baring the few exotic exceptions, you'd do better to look elsewhere for more hp.
Originally posted by chimshady1
ProMod-Did u have a dyno tune?What was your airfuel?Cant believe they set the chains wrong.It's not the first i heard of that.I just cant see how someone could overlook that.
Some have run 26 degrees with 91 octane and no detonation with water/alcohol injection. 100 Octane is expensive. 116 cost even more. Water/alcohol is real cheap and works better than 116 octane race fuel.
