DIY Driveshaft Loop
Old Oct 25, 2004 | 06:48 PM
Almightywad's Avatar
Question DIY Driveshaft Loop
I've read a couple of posts on this website of people who built their own driveshaft loop but I didn't see the dimensions used for the loop itself. I've found all the hardware needed but I need to know the dimensions of the loop. Can anyone help?
Old Oct 25, 2004 | 07:11 PM
LightningTuner's Avatar
I have no problems with people trying to make their own stuff, but why not just spend $70 and buy one? What kind of driveshaft loop are you going to make that's NHRA legal? You're not going to bend 1/4" thick x 2" wide steel with average garage shop tools.
Old Oct 25, 2004 | 07:22 PM
I have the tools to make it. I don't need to spend $70. That'll buy 2 custom tunes down the road. Would you be willing to give the dimensions of the loop?
Old Oct 25, 2004 | 07:35 PM
cpeapea's Avatar
you could probably do it with an oxy fuel torch and a vise. take a few measurements underneath and line up the holes.
Old Oct 25, 2004 | 07:59 PM
Lining up the holes is the easy part. I need to know the dimensions of the loop so I ensure proper clearance from the driveshaft and other surrounding parts.
Old Oct 25, 2004 | 08:11 PM
bglanden's Avatar
I would assume greater than 4.5"s!LOL. I plan on doing the same thing as I have access to 2" mild flat steel and a torch. If I do this in the next few days I will let you know. But then again, maybe pole vaulting will get me further into the 12's!
Old Oct 25, 2004 | 08:14 PM
HA!!!
Old Oct 25, 2004 | 08:43 PM
WaveBlaster785's Avatar
That's easy.
Step one: Jack up truck
Step two: Lay under truck
Step three: Locate driveshaft
Step four: Measure
Step five: Work for 4 hours making a D/S Loop you could have bought for 70 bux.
Step six: Fight to install home made D/S Loop
Step seven: Wonder if it was worth it
Old Oct 25, 2004 | 08:49 PM
bglanden's Avatar
Originally posted by WaveBlaster785
That's easy.
Step four: Measure
The fact you did it yourself......priceless! pun intended!
Old Oct 25, 2004 | 09:33 PM
All I ask for is some dimensions and it turns into a flaming contest. It is worth every minute I spend in my garage working on my truck. No kids, no wife. So, I can spend some extra time making something of my own or I can spend $50 extra dollars so I can go back in the house sooner. You choose.
Old Oct 25, 2004 | 09:47 PM
Seeing as the only people who would probably know that without going outside to measure are the people who make them or sell them, I would try to see the dimensions on the universal d/s loop from jegs that someone posted about a week ago
Old Oct 25, 2004 | 09:55 PM
My post numbers are low because I find most everything I need from searches. Not all searches turn up what you're looking for. I don't post here to get my numbers up as you can see and I don't spend much time posting on this site because of crap like this. Thanks for your time and help.
Old Oct 25, 2004 | 10:06 PM
soap's Avatar
I made this one myself in only an hour or so.......
No need to bend anything. I cut an 8" pipe into a 2" wide piece. Then cut it in half and welded in 2" more for extra clearance since my truck was lowered.
I should have powdercoated it instead of painting it.......you can see it starting to rust.
Grade 8 hardware from Lowes was my only cost.
--Joe
Old Oct 25, 2004 | 10:09 PM
Great pics, thanks. Good point on taking ino account lowering etc.
Old Oct 25, 2004 | 10:17 PM
Don's Bolt's Avatar
Check these threads
https://www.f150online.com/forums/sh...riveshaft+loop
