Guess my HP, going to Dyno tomorrow
going to dyno tomorrow and will post results... I was doing math in my head and came up with a number, but not sure how realistic that is...
give me your thoughts...
last time I dyno'd I pulled 398rwhp... this will be on same dyno and pretty close to same weather. Except these mods were added
1. Full Exhaust (kooks LT, high flow cats, xpipe, dual magnaflow)
2. efan
3. power plenum
4. 2.8 upper (already had 4lb lower)
5. phenolic spacer
6. idler
7. accufab
i dont have a reburn for all this stuff yet, thats what im getting this dyno for, then will get a new SCT program from JDM next week and hopefully tweak it and gain even more power....
2. efan
3. power plenum
5. phenolic spacer
6. idler
7. accufab
oops my bad didn't see the exhaust...well forgot that was at the top. Then ya probly around 430 give or take 5. Good luck and let us know the numbers! I'm a retard lol, also didn't see the 2.8 upper being added
I'm outta it today sorry
-Sly
BTW what were your previous mods?
I'm outta it today sorry-Sly
I hate seeing these posts. My truck dynoed 385/450 with the following:
Apten
4# lower
Bassani Cat-Back
Efan
90mm intake
conical filter
SBTB
chip
and my tuner says that is what to exect with these mods on a 2000 and that I am where I should be. Keep in mind that it is one of the main 3, so it isnt like I dont have a reputable tuner.
With that being said, and assuming you have a 2000(00Bolt), I dont think you should expect much more that 410 or so, but I know other people are gonna say 430-440ish.
-Kimball
Apten
4# lower
Bassani Cat-Back
Efan
90mm intake
conical filter
SBTB
chip
-Kimball
when i had the 398, i had just
4lb
jlp ram air
ported eaton
psp chip (now have SCT dyno from JDM)
90mm
ftvb
4lb
jlp ram air
ported eaton
90mm
ftvb
You will lose some boost with the headers. When I put a new stock engine in 6 months ago, I added headers, high flow cats and catback. I lost about 2lbs of boost. You should get your chip reburned when it is on the dyno tomorrow.
That's what I'm doing tomorrow @10am.
- Later
- Later
