damn rubber!
Old Oct 18, 2004 | 11:39 PM
jerzey storm's Avatar
damn rubber!
what do you guys use,ive tried acetone,bug and tar, 3m road tar remover, wd-40, gasoline,and some other forgotten ones, and this ***** is just laughing in my face, what do you guys use or what have you heard of that works really well to remove the rubber.
Old Oct 19, 2004 | 12:25 AM
Don's Bolt's Avatar
I have allways had good luck with this
Old Oct 19, 2004 | 12:32 AM
SlowSVT95's Avatar
Old Oct 19, 2004 | 12:33 AM
SlowSVT95's Avatar
Ummmm yeah, clean that *****.
Old Oct 19, 2004 | 01:36 AM
Patrick_PDX's Avatar
If you KNOW your going to burn some rubber, spray some Pam non stick cooking spray on anything that the rubber might hit.
Old Oct 19, 2004 | 06:47 AM
SVT_KY's Avatar
Pam will discolor the clear coat ... Very noticable on white ...
Old Oct 19, 2004 | 10:06 AM
Konig's Avatar
I have never done a crazy burnout like that but I always just wipe it all off after a run at the track...it comes off easy when its fresh...you can use just about any cleaner to wipe it when its like that....I use a paint scraper for inside the wheel wells when I get home.
Old Oct 19, 2004 | 12:01 PM
SVT_KY's Avatar
Vaseline Rulz !!!
Old Oct 19, 2004 | 12:14 PM
VINNIE's Avatar
Old Oct 19, 2004 | 12:39 PM
MaxPower's Avatar
I've used Tire Wet prior to a trip to the track ... Spray the whole inside of the wheel well, and the rear quarter panels. Washes right off.
To get it off, you're gonna need A LOT of elbow grease to get it off the untreated paint. Get out lots of rags, polish, etc. The plastic inside the wheel wells, you can rub it off with a plastic scraper or your fingers (on the indented areas)... Not fun.
Old Oct 19, 2004 | 01:19 PM
I8ACAMRO's Avatar
I had good results with JetA (similar to Diesel)
Old Oct 19, 2004 | 01:37 PM
Blown93's Avatar
Amazing burnout........... Betca he needs some new tires............
PEacE...................
Old Oct 19, 2004 | 02:12 PM
mhays26's Avatar
Those are some sweet pics and a sweet bunout. One day Im going to get one like that.
Old Oct 19, 2004 | 02:16 PM
1 Clean 02Bolt's Avatar
SICK smoke show indeed!!!
You're gonne need a pressure washer, some Simple Green (at full strength) and a clay bar (I recommend the Mother's clay).
Spay the rubber blasted areas with a liberal amount of Simple Green and let it soak for about a minute. Hit the areas with the pressure washer....that should get all the big chunks off. After your done with that wash the whole truck with a good car wash shampoo and dry. Next clay bar the affected areas...this should pull the remaining rubber off.
Time is of the essence for you...the longer you let the rubber stay on the paint the better chance you will have that it will stain and/or eat through your clearcoat.
Old Oct 19, 2004 | 04:43 PM
Anthony@JDM's Avatar
The Burn out Conest was not something he intended on entering untill myself and few friends talked him into it.
