"SVT" on Lightning blower nose
Old Oct 14, 2004 | 08:52 PM
adami67's Avatar
I see that the 2001 and above have "SVT" on the blower nose instead of "EaToN" which looks to be on the 2001 and older.
Is there a difference in these blowers?
Old Oct 16, 2004 | 08:00 PM
Twisted99's Avatar
yes and no..the 2001 and up have a different flange ....
Old Oct 16, 2004 | 09:37 PM
l-menace's Avatar
they are a rare special edition. If you can get one, snag it up quickly. The gear ratios are different thereby producing more boost, but very few know about this..
If you aren't going to get it, send me a PM and I'll look at it
Old Oct 16, 2004 | 10:09 PM
motleycrue's Avatar
Menace you mean to tell me the that if you have SVT on the front of the blower its different than some of the other lightnings made? Just checking. THanks
Chris
Old Oct 16, 2004 | 10:11 PM
Konig's Avatar
Don's Bolt's Avatar
Chris
Hehe
Don't listen to that bonehead
They are all the same.
Mine says Eaton
Old Oct 16, 2004 | 10:25 PM
motleycrue's Avatar
well i mean i was just curious, mine says SVT on it
Old Oct 16, 2004 | 11:25 PM
brahmus's Avatar
Adam i know what you are after, the pre 01 blower ASSEMBLIES had a faulty intercooler if you are looking for the assembly pay the extra and buy the SVT edition.
Old Oct 17, 2004 | 10:21 AM
adami67's Avatar
Hey all,
Thanks for the laughs (peanut butter filled) as well as the more helpful comments.
Reason I asked was because I purchased the SVT assembly.
This assembly is a 2001, 10row intercooler, SVT unit.
I'm looking forward to installing it.
Old Oct 18, 2004 | 08:26 PM
Twisted99's Avatar
Funnt..My 01 says Eaton....and it's the new Blower...
Old Oct 19, 2004 | 12:59 AM
motleycrue's Avatar
So to sum this up what is the real difference between the two of them? Mines a 2001 and it says SVT on it. IM really curious about this now.
Old Oct 20, 2004 | 01:29 AM
Her2001's Avatar
I also have an 01 here which says Eaton. So is it interchangeable with the 2002 + SVT mark SC?
Old Oct 20, 2004 | 03:16 AM
kerno's Avatar
I had a chance to compare the bottom of a 1999/2000 blower with the "early" bolt pattern and the bottom of a 2001/2004 blower with the "late" bolt pattern. The main housing castings appeared to be identical and the only difference is which set of bosses have holes drilled in them. It is as if they knew the change was coming. The SVT/Eaton logo on the blower snout casting was probably a mid production change.
Old Oct 20, 2004 | 09:56 AM
adami67's Avatar
Kemo,
You're probably right that the "SVT" logo addition was a mid-year sort of thing.
There's got to be a Ford history expert on this board that can confirm.
