SES light on..bank 1 and 2 system too lean
Hey
Well i bought my 2001 lightning about a month and half ago and love it since then, and as soon as i got it i added a CAI, 2.70 blower pulley, exhaust, did the boost bypass and got it custom programmed. About 2 weeks ago the SES light came on. I disconnected the battery and a couple hundred miles later it came back on. I took it to my friend and he hooked up his code reader and got both BANK 1 and BANK 2 system too lean.
What does that mean?
What should i do?
I suspect a bad 02 sensor or fuel injectors. I've been here a lot lately doing some reading and found a lot of you very knowledgeable so any help would be great. Thanks!!
-netoje
What should i do?
-netoje
SES lean codes
I recently got the SES light also. The code showed lean condition in Bank 2. I had a tech clear the codes and the light lit up again about a week later with same code. The only recent mods I had made to the truck before the code was a new JLP ram air intake. Based on some info on this site, the suggestion was made that the oil on the new air filter may have fouled the MAF. Check your MAF and see if that might be the cause. I will be checking mine this weekend to see if it the problem.
when i changed to an inlet pipe i had trouble connecting the 3 lines that go to the bottom of it. theyre are in but not all the way completely could that also be the cause?
yes that would do it! The three llines that is.
What ever you do until you get your problem solved...
DO NOT GO TO WIDE OPEN THROTTLE
Suavy
Suavy
I got banks 1 and 2 lean the other day....
check all the plumbing...
reset the code.....funny thing is this is after I washed the truck.....
next day I get an SES and check for codes..no code...just the light....?
reset the light.....
today I wash the truck......
start it up moved inside and shut off....
pulled the passenger side door off to check a speaker problem...cranked it back up....
SES lite....plug in the Predator.....
Bank 1 lean.......
reset....I have a strange feeling..next time I wash the truck I'm gonna get a SES lite....
Strange......
Bank 1 lean.......
Strange......
what would be the consequence if i went into WOT? the 3 lines are in but theyre not flush against the inlet pipe, is that still a problem?
any one know the location of the o2 sensors?
You can also remove the chip and see if that is causing the trouble. It should be ok to run with just a upper pulley for a while.
Suavy
