Routine Maint.
Old Oct 12, 2004 | 10:14 PM
USMCJon's Avatar
Routine Maint.
Well my parts should be comming in this weekend to fix the pitman arm shaft leak that has my truck deadlined. While Im at it I figure I'll do some routine maint. Plan on pulling the Eaton to clean the IC, replacing the plugs, fuel filter, and installing that PCV mod after everything is cleaned up.
What are some other maint. procedures I may be forgeting? (pls dont mention chaning the oil)
Also where are some of the places you guys go to buy parts online?
Thanks,
Jon
Old Oct 12, 2004 | 10:34 PM
Don's Bolt's Avatar
Change the trans fluid and filter
flush and refil the coolant and intercooler systems.
Replace and Blead the brake fluid
Old Oct 12, 2004 | 10:53 PM
USMCJon's Avatar
Good call Don. Any tips on the tranny fluid/filter change? Which oil to use ?
