Lean Banks 1 and 2 ?
Old Oct 9, 2004 | 01:11 PM
Twisted99's Avatar
are these codes associated with a dirty EGR valve or a marginal O2 sensor ?
Old Oct 9, 2004 | 01:50 PM
FLOORD U's Avatar
it's fuel delivery...put a f.i. fuel pressure guage onto your shrader valve on the fuel rail. wrap a towel around the line run it up by the windsheild close the hood down to the safety latch and take it for a short drive.
should be 38ish at idle and ramp up under load going down the road.
after you determine if it's low fuel psi or not; you'll be dropping the fuel tank to repair/replace the rubber lines that run from the plastic Y connector to the 2 fuel pumps.
perfect opportunity to replace the stock pumps with a dual 255 set up. i did . got'em from sal
fyi...this happened to mine shortly after i changed to a garbage can lid sized lower pulley.
good luck,
pat buchanan
p.s. other than that it could be a massive vaccum leak.
Old Oct 9, 2004 | 03:15 PM
l-menace's Avatar
I take it you have a'99 (twisted99) what MAF sensor do you ahve on it.
Old Oct 9, 2004 | 03:43 PM
Calightnin's Avatar
Fuel pump.
Old Oct 9, 2004 | 03:58 PM
superfords's Avatar
I say vacuum leak, tune, or maf.
good luck.
later,
chris
Old Oct 9, 2004 | 04:07 PM
l-menace's Avatar
good luck.
later,
chris
agreed... maybe a bad O2 sensor, but that would lead to a different code.
is the truck shifting differently? If not, you can probably rule out the MAF.
check all the black plastic hoses for a crack or unpluged. odds are this is your problem
Old Oct 9, 2004 | 05:09 PM
LightninMike's Avatar
my truck tossed that code when i did the dime mod
pulled the dime and all was fine
Old Oct 9, 2004 | 05:26 PM
cpeapea's Avatar
i assume you do have a new fuel filter too right?
Old Oct 9, 2004 | 06:47 PM
tallimeca's Avatar
hmm
i thought that our trucks read 32lbs at idle??????
Old Oct 10, 2004 | 12:31 PM
Twisted99's Avatar
NO Ihave a 01...had 2 99's..The first one was....Twisted..as in totaled.....
Just installed a new fuel filter....
stck MAF....RWTD Predator Dyno tune....
making 410 RWHP and 500 FT pounds
SAE
shifts fine.....
Autometer Fuel Gauge shows good idle and
otherwise fuel presure...
did a quick check of the intake boot lines seem fine..guess I'll start looking harder....
thanks for the input....
truck has 89000 miles.....
ported eaton...4 pounder...BR7EF plugs @.036 gap..JLP intake....160 degree hypertech.... E-Fan ..FTVB..stock fuel pumps m
I have reset the codes...drove several miles and no code yet.....
Old Oct 10, 2004 | 04:32 PM
jarmstro's Avatar
Lightbulb
Put your stock breather cap back on, assuming you have an aftermarket one.
Old Oct 10, 2004 | 04:58 PM
Twisted99's Avatar
Nope..stock breather with upgraded PCV ...
just pulled the EGR and cleaned..it was dirty but not nasty..
Old Oct 11, 2004 | 08:55 AM
93Cobra's Avatar
Clean your MAF... should make your problem go away. My dad's truck had this same issue, and we found it to be the MAF sensor was dirty. I would clean that, then check it to see if the problem clears up. He had this happen around 125,000 miles or so.
