C & L Plenums Dyno Tested
Old Sep 30, 2004 | 03:40 PM
Anthony@JDM's Avatar
We are now selling the C&L Plenums, they are in stock. On a basic bolt on truck we picked up 14 rwhp horsepower where it is needed at the top end. Kenne Bell truck picked up 21 rwhp & we are now doing a Magnum Power Bolt on truck right now.
Price is $289 + S & H.
Here are some pictures...
Old Sep 30, 2004 | 03:46 PM
l-menace's Avatar
21 hp?
how much on a BONE stock lightning?
Is the stock intake that restictive under 450rwhp? (figure with the KB, you are at least at 500rwhp, more than the average lightning owner)
Old Sep 30, 2004 | 03:56 PM
03WHITELIGHTNIN's Avatar
Originally posted by l-menace
21 hp?
I'm with him, does this really help on trucks that have under 450? Is this with stock TB or aftermarket?
Old Sep 30, 2004 | 04:02 PM
01svtL's Avatar
What does it do as far as intake temps? Are they lowered at all or what exactly is the advantage of this plenum besides 14 hp for $300?
Old Sep 30, 2004 | 04:04 PM
PhillipSVT's Avatar
nice breather cap...
Old Sep 30, 2004 | 04:10 PM
lightninquick's Avatar
anthony
i have the magnum and i am running almost 18 pounds of boost at sea level. do you think this might add or subtract any boost?
Old Sep 30, 2004 | 04:16 PM
21 hp?
We have not Dyno Tested a Bone stock Lightning. You will see gains on a truck that makes under 450 rwhp and over 450rwhp i.e a Kenne Bell Truck. The power curves will change depending on the mods each diffrent truck has. The truck that gained 14rwhp truck had a 4 # lower, SCT 9100, Throttle Body and an Air kit.
zbornac's Avatar
HA HA, LOL.
-Kimball
Old Sep 30, 2004 | 04:19 PM
I have no info yet on the intake temps. As far as the plenum you will also see throttle response, besides 14 rwhp.
Old Sep 30, 2004 | 04:20 PM
00Bolt's Avatar
does this effect the boost at all either way??
and im sure its does, but does it require a new dyno for A/F and reprogram?
Old Sep 30, 2004 | 04:27 PM
Originally posted by lightninquick
anthony
It will add boost. Some where around 1 pound or more.
Old Sep 30, 2004 | 04:29 PM
It adds boost approx. 1 pound or more, The Plenum does lean out the A/F up top so I would have your tune checked and/ or ajusted if you do this mod.
Old Sep 30, 2004 | 04:56 PM
CHIKIN1's Avatar
How much horsepower will you gain on a truck with a JDM built motor w/ported heads and cams, KB @ 18psi, a "wet" 75 shot and 16 degrees timing that already makes 680 RWHP w/o N20??
What??? You don't know...guess you'll find out in a few weeks huh???
Old Sep 30, 2004 | 05:07 PM
GET THE BUZZER OUT JAMES
You coming up anytime soon?
I haven't been back to the Den, I can sur use a reason to go.
Old Sep 30, 2004 | 05:08 PM
CHIKIN1's Avatar
I'll be up toward the end of the month
I hope Sophea is ready...I know I am
