am i dont with the "basics"... whats next?
Old Sep 30, 2004 | 02:55 PM
00Bolt's Avatar
am i done with the "basics"... whats next?
im done!!!
ported blower
4lb
accufab
full exhaust (kooks,cats,magnaflow)
SCT + dyno tune (JDM)
traction bars + slicks
90mm
efan
jlp ram air
ftvb
i think thats about it... maybe some other small stuff like boost bypass....
Old Sep 30, 2004 | 03:20 PM
03WHITELIGHTNIN's Avatar
c&l upper intake
Old Sep 30, 2004 | 03:35 PM
00Bolt's Avatar
i have thought of that before.... other than the fact it looks nicer.... is there really any performance gains in the C&L intake?
Old Sep 30, 2004 | 04:01 PM
check out JDM's post. They claim 14 hp on a modified L (basic bolt on) I believe Frank5L picked up like 26 or 27 in torque.
Old Sep 30, 2004 | 04:07 PM
LatemodelRacer2's Avatar
get the C&L upper intake and the phenolic spacer. Or you could always go the 35 shot nitrous route but that doesnt last long before it becomes a 50 then a 75.
Old Sep 30, 2004 | 04:21 PM
it is about time for a 100 shot aint it?
Old Sep 30, 2004 | 04:34 PM
35thPony's Avatar
If I were you it would be in this order:
C&L Plenum...
Wide Band Commander (highly recommended)
QA1 shocks
I have the signature below and I have sitting in my living room
e-fan
cobra water pump
170 thermostat
Sylvania HID Xenarc head lights
I have backordered, should ship next thursday
C&L Plenum
Single Blade Throttle body
traction bars
QA1's (not ordered, yet, waiting on a possible group guy)
Don't know if there is anything else for me either....
Old Sep 30, 2004 | 04:38 PM
00Bolt's Avatar
can ya give me more info on the wide band commander... dont know much about that
btw, i thought at first you were talking about the c&l intake boot... that silver/blue thing..... are those worth getting or more a pretty dress up thing
Old Oct 1, 2004 | 01:05 AM
naw i got a magnum powers on the way nitrous is going back to 35
Old Oct 1, 2004 | 01:37 AM
Duende's Avatar
Great suggestions above... Only two other things popped into my head. DS Loop and Interchiller.
Old Oct 1, 2004 | 02:20 AM
teamsvt2002's Avatar
You have a new setup so far. I would go for a torque converter 2400-2600. I think you will get the most benefit out of what you got so far.
The heat exchanger is ok I guess I didn't see no gains from it. The only reason I have it is that found a person that would buy my stock heat exchanger for $400.. I know what a deal. Paid 389 for the new heat exchanger.
I self ported my plenum with a pencil grainder in less than an hour taking my time. I am really pleased my results. I installed the pholonic spacer with a slight port job and made sure the openings matched. So you can go away without the C&L Plenum if you don't mind doing it yourself.
Old Oct 1, 2004 | 06:34 AM
00redLrod's Avatar
Registered User
[QUOTE]Originally posted by 00Bolt
[B]can ya give me more info on the wide band commander... dont know much about that
I too would like more info on the Commander if anyone can explaine it in lamen terms
Alex
Old Oct 1, 2004 | 08:29 AM
Blown347Hatch's Avatar
http://www.widebandcommander.com/index.htm
Old Oct 1, 2004 | 08:33 AM
mhays26's Avatar
http://www.nloc.net/forum/showthread.php?threadid=79757
Old Oct 1, 2004 | 08:47 AM
35thPony's Avatar
Yep, read the link above... It basically is a unit that will data log your rpm's/af/throttle % and show you on an easy to see laptop screen and if you don't want to have the laptop in the car... you just flip a switch and it will record it in it's little brain and then you can down load it later. It also has an a/f guage with it that is very accurate since it is hooded directly to a coil plug, tps sensor, and had it's own HIGH QUALITY O2 sensor that you hook into your exaust... It is a great setup and allows you to keep an eye on what I think is the most important number a/f. It prints it on a gragh that looks just like the bottom of a wide band run on a dyno...
