ZEX install Q.
ZEX install Q.
when tapping into the TPS...which wire do i connect the white wire supplied into? and also any tips in the best place to tap into the fuel system for the fuel delivery??? the hoses that come with the kit arent very long...
If I remember correctly it is the middle wire you tap into for the TPS. And what most people do is get the adapter to screw into the fuel shrader valve on the back side of the passenger fuel rail.If you have a multi meter you can check the Wires going to the TPS and see which one has less than 1 volt on it and will increase when you open the throttle just turn the key to the on position and check the voltage you do not have to start it but you do have to have the key in the run position.Hope this helps.
jeff
jeff
