header install...sucks!!
Old Sep 24, 2004 | 11:53 PM
LeoGSVT's Avatar
i got some Dynatechs and i planned on installing them myself...but me and a buddy have been working on the pass. side long tube for 2 hours now and can not get it to fit...either the gasket keeps slipping off or i cant menouver it with such limited space...any tips on the passenger side install?? driver side is done...I WANA FIRE THIS THING UP ALREADY!!!!!!!!!
Old Sep 25, 2004 | 12:06 AM
Hilander's Avatar
I just did the Kooks, the passanger side was a bit more tricky for sure..
I don't get the gaskets keep falling out? Are you using the stock ones or after market?
Are you saying the header is lined up but you can't get the bolts in?
Old Sep 25, 2004 | 12:36 AM
LeoGSVT's Avatar
i cant seem to get the bolts lined up...i had one hell of a time gettin the actual header up into place...with that heat sheild in the way...im using the aftermarket gaskets they sent with the kit..i wish i could show you some pics....
Old Sep 25, 2004 | 08:40 AM
AZ fun's Avatar
If you thought long tubes were tough try and put bassani headers on. I will never do that again..... They are on the truck permenant now.
Old Sep 25, 2004 | 10:40 AM
camcojb's Avatar
I've done Dynatechs and LFP's on my truck; the Dynatechs were definitely the easier of the two to install.
On the passenger side they come up from underneath, didn't have to remove anything. They sent me gaskets like the factory metal ones where you could start the two end bolts in the headers THEN put the gaskets in; much easier that way. There was a bolt or two on that side that were fun to get in and tightened up, but other than that it went pretty well. I do have a car lift too though, and that undoubtably helps.
You do have the inner fenderwell removed, right?
Jody
Old Sep 25, 2004 | 01:08 PM
Certified Drunk's Avatar
With the inner fender out ant the battery cable disconnceted from the starter they shoud slip right in.
Old Sep 25, 2004 | 06:19 PM
Skank Dog's Avatar
It took me and a buddy 3.5 hours to install the Dynatech's on my Lightning and we've been in the auto business for years. We have
lifts and all the nec. tools we needed, so if your doing this in your driveway or garage on jack stands, Id plan on making a day of it.
If you havent already, I would remove the front tires and RF fenderwell, make for alot easier access. Just take your time and dont get in a big hurry. The sound is to die for!! Ive had several compliments on the sound already. Good luck!!!!!
