Leaf springs help
Leaf springs help
So there I was knee deep in the.....kidding. Check it out,I plan on getting new leaf springs for my 03 since I am replacing most of my suspension anyways and the rusty stock ones bug me.I called the Ford dealer to see about getting 00 leafs so I could bring the *** end down a bit and ol' boy gave me the same part # XL3Z-5560-AA (Code S)for both. I thought the leafs in the 03/04 would be a different part # then 99-02 since they sit lower in the *** end then mine do.
Can I get some clarrification,I will order another set for my 03 either way but would like leaf springs from a earlier model if possible.
Thanks guys.
Thanks guys.
Originally posted by ZEM'S04 L
Yeah I think you are right, in the 03-04 models they added a leaf spring to the suspension.
I just removed the next to bottom leaf from the springs on my 01. It dropped the A$$ end about 1- 11/2 inch I moved the rear shackle up untill i get some drop springs on the front so the rear wouldnt be sitting lower
Originally posted by Unoid
if you're going to change leafs you might as well get aftermarket 2" drop leafs,
forgot which company? roush?
