Need Injector advice
Old Sep 18, 2004 | 03:56 AM
8UR LS1's Avatar
Question Need Injector advice
What kind of aftermarket squirters would you guys recommend
with the Magnum and stock block, 50#,55#,ect.
Why and what kind (MSD,Delfi,Semeins)?
Will the 55# injectors be to big and overwork the stock pumps?
Will the 50's be to small when i go to upgrade the stock internals and push bigger #'s like (550/650)?
I'm currently not feeling comfortable with the 42's in there with the Magnum at 15-16 #'s boost and still thinking about putting the 6# lower ring on to spin her just a little harder like 17-18#'s with a safe tune
Feel free to chime in
Old Sep 18, 2004 | 06:58 PM
Spanky99L's Avatar
i currently run 60lb semens deka high-impedence ans i'm putting down 478 at the wheels with stock eaton no nitrous. I went with the 60's because for 20 bux more i went ahead and got them. Besides i might need them for my next upcoming "project"
hehehe
Will
Spanky99L's Avatar
oops
Old Sep 18, 2004 | 07:07 PM
Odin's Wrath's Avatar
I got the 60# injectors since they cost about the same. I know I'm not through modding yet. Even though I keep telling myself I am.
Old Sep 18, 2004 | 07:09 PM
Calightnin's Avatar
Get the 60's. You will not over work the pumps.
Old Sep 18, 2004 | 07:19 PM
superfords's Avatar
I also use the 60s, I forget who makes them, I got them from Sal@PSP.
I do have the 255lph pumps though.
I dyno'd the truck again today and on the mild tune it did 519/585.
Old Sep 19, 2004 | 02:19 PM
8UR LS1's Avatar
Wow, those are some big #'s for the stock heaton,(ported or not)
you must be running like 18-20#'s boost though that thing!!!!
I still think 60's are still to big for my set up
Who's got a good deal on some 55's?
Old Sep 19, 2004 | 03:23 PM
superfords's Avatar
mine did 519HP on the eaton and a street tune yesterday, but mine is ported. I'm still looking to get some more out of it though.
Old Sep 19, 2004 | 04:10 PM
8UR LS1's Avatar
You must have a built block with a stout head/cam combo to push those #'s
Old Sep 19, 2004 | 04:24 PM
Calightnin's Avatar
Unless the injectors are so big that they screw up your idle they really can't be too big (and these injectors arent that big). They don't use more fuel they just open less. Get the 60's!
Old Sep 19, 2004 | 09:10 PM
tlfwatch's Avatar
Question WHAT SIZE INJECTORS DO I NEED
modded with 6# lower 2.80 upper metco idler modified air box k&n filter diablo sport ship tuned for 93 octane ftvb fluidyne heat exchanger transmission cooler etc/?????? so what size injector should i be running thanks 2003 lightning
Old Sep 19, 2004 | 09:26 PM
Calightnin's Avatar
I would expect that you are fine with the stock injectors.
