Is there a larger fuel filter that fits......
Old Sep 17, 2004 | 03:00 PM
Blown347Hatch's Avatar
the Lightnings?
I looked at it the other day, and no wonder they clog in no time.
I thought I read that the Expedition filter is much larger, and the connections are the same?
What's the largest filter I can run?
Old Sep 17, 2004 | 04:15 PM
Konig's Avatar
You can fit the Navigator filter just fine... you really have to cram it behind that rentension clip...but it works. I used one a few changes ago with no problems. I would say its the largest you can use..seeing as physical space is at a premium
Old Sep 18, 2004 | 10:15 AM
Thanks. Does it matter what year?
Old Sep 18, 2004 | 02:46 PM
getzbusy's Avatar
i got my fuel filter from JLP i dont know what its off of, but its big and it fits, give them a shout
Old Sep 18, 2004 | 03:32 PM
It's bigger than the factory one?
How did you mount it?
Old Sep 18, 2004 | 04:32 PM
0light1's Avatar
Here is the one I used.
With a little muscle the clamp will clamp in the middle of the filter and actually hold it in. I use wire ties just to be safe.
Old Sep 19, 2004 | 10:55 AM
Konig's Avatar
It has to be for a navigator from 99+ I think... I didnt use any zip ties. I just pulled that bracket far enough to cram it in there....its not easy, but if I can do it anyone can.
Old Sep 19, 2004 | 11:14 AM
black f150 offroad's Avatar
The large filter is an FG 872 (motorcraft/ford) It was used on pre 99 trucks and other vehilces, in 99 they switched to the small filter except on superduties - they still use the fg 872
Old Sep 19, 2004 | 11:18 AM
99SVT's Avatar
Actually the filter that is on our trucks is the one that fits a V6 F150... just get a filter (which is what everyone is showing in the pics) that fits a 5.4L F150. All the parts houses I've been to around here will bring you out the big one when you go in to get a filter.
And it does not have to be zipped tied or put back into the clamp. I just set mine back up on top of the lines... it stays there quite fine. I have 116k miles on my Lightning, with the filter changed every 10k miles and it has never caused me any trouble doing it this way.
Old Sep 19, 2004 | 01:28 PM
Thanks guys.
So the Navigator/Expidition filter is the same for any V-8 modular motor?
99+ would be the years to ask the parts guy for.
I need to see if the local Wal Mart has it in motorcraft part number mentioned above.
Again, thanks guys.
