Stock plugs in 03, and what plugs for 6lb lower..
Like the title said. I used to own a 99L, just checking to see if they changed plugs in 03. I remember running NGK TR6's on a 4lb pulley back then, now I'm looking to go to a 6lb pulley on the 03, will the TR6's be a good choice or should I go with something else.
-Sly
-Sly
BR-7's are known for SOMETIMES giving you trouble on the street.
But I can say from experience, I've been running THE SAME
Denso IT-22's through the last 3 summers, and have NO ISSUES.
They run PERFECT from idle to 6000 RPM. And I also use them with only 4lbs of Pulley through the Cold months ALSO TROUBLE FREE
Yes more than 4lbs and you should go 2 ranges cooler
