Code p0153- O2 sensor Circuit Slow Response (Bank 2-Sensor 1)??? Help????
Old Sep 16, 2004 | 10:53 AM
tallimeca's Avatar
Posted about truck almost stalling the other day. All of a sudden service engine soon light came on. Pulled code P0153, which says slow respone from bank 2 sensor 1. Any ideas.
I did my headers and high flows a couple weeks ago and it's been fine, now this.??????????????????????????????????????
Old Sep 16, 2004 | 11:17 AM
tallimeca's Avatar
bump
keep'n it to the top yo, wicky wicky wicky
Old Sep 16, 2004 | 11:26 AM
superfords's Avatar
normally that would indicate that you need a new sensor.
assuming you haven't melted or chaffed any wires due to the header install.
good luck.
later,
chris
Old Sep 16, 2004 | 11:29 AM
tallimeca's Avatar
Chris
any special sensor i should use??? Are they the same as regular f150???
Don
Old Sep 16, 2004 | 01:23 PM
Anthony@JDM's Avatar
Don, remove the bad one and bring it to Ford and have them use the part # off it as a reference.
Old Sep 16, 2004 | 02:37 PM
bad00's Avatar
anyone know witch sensor that is" bank2 sensor1" ,,I got the same code?????
Old Sep 16, 2004 | 04:09 PM
EvilL's Avatar
Bank 2= Passenger side
Sensor 1 =Front 02
Old Sep 16, 2004 | 06:35 PM
tallimeca's Avatar
crap
i replaced the sensor and the code hasn't returned but the truck is falling on it's face. Kinda feels like when i blew a coil pack 2 years ago. Could these two have any relation.
Another thing........my wide band is bottoming right out at 18 when this stumble starts to occur. What the ****. I hate when **** is broke
Old Sep 16, 2004 | 07:43 PM
l-menace's Avatar
I have 8 o2 sensors sitting at my house forsale.
$15/each.
Old Sep 17, 2004 | 01:11 AM
MaxTorque02's Avatar
$15/each.
What brand and what model number?
Old Sep 17, 2004 | 01:21 AM
Sensor 1 =Front 02
Are you sure about that? I'm pretty sure that's what my code was and it was the drivers side upper oxygen sensor.
Old Sep 17, 2004 | 05:49 AM
Fast Gator's Avatar
ditto
Old Sep 17, 2004 | 01:02 PM
bad00's Avatar
doh!!!! now I'm all messed up
Old Sep 17, 2004 | 02:06 PM
EvilL's Avatar
The Front 02s are interchangeable so you should be able to swap them and see if the code changes.
MaxTorque02,
Your right, Bank 1 is always the side with cylinder 1 on Fords AFAIK
