Engine Removal
Old Sep 28, 2004 | 10:57 AM
TampaBlack99's Avatar
All your pdf's have to do with rear brake's, is front brake maintenace any different and if so, can you post that info also?
I secound header install with torq specs and bolt sequence.
Old Sep 29, 2004 | 09:47 AM
I would also like to see:
- Steering Box Replacement
and
- Replacing front suspension parts (pitman arm...)
Old Oct 2, 2004 | 12:32 PM
SVT_KY's Avatar
Front Brakes added
Old Oct 2, 2004 | 12:34 PM
SVT_KY's Avatar
and
Can't find specific instructions, but the power steering
instructions might be enough ...
Old Oct 2, 2004 | 10:32 PM
Thanks, is there any info on replacing the water pump?
Old Oct 3, 2004 | 01:36 AM
SVT_KY's Avatar
Done ... Engine section
Old Oct 3, 2004 | 04:13 PM
How about Rear Diff fluid change and front control arm/ idler arm replacement.
Rear gear replacement
