TSB for 2002 Lightning
Old Sep 10, 2004 | 06:59 PM
SVT_KY's Avatar
Found this and thought I would leave a trail here....
TSB Number Issue Date TSB Title
04-8-3 MAY 04 Electrical - Correct Wire Splicing Procedure
04-5-7 MAR 04 Body - Front Window(s) Pop/Thump Noise at End of Travel
04-2-2 FEB 04 Body - Sliding Back Glass Windnoise/Water Leaks
03-26-1 JAN 04 A/T - 4R70W Needle Bearing/Race Kit Service Tip
03-23-5 NOV 03 Body - Bed Extender Component Replacement Tips
03-23-2 NOV 03 Body - Exterior Mirror Glass/Motor Service Tips
03-22-4 NOV 03 Wheels - Correct Lug Nut Torque Specifications
03-18-1 SEP 03 Keyless Entry System - Service Tips
03-15-13 AUG 03 Steering - Tie Rod End Inspection Procedures
03-11-10 JUN 03 Body - Moonroof Water Leaks/Won't Open Properly
03-11-6 JUN 03 Electrical - Wiring Soldering/Crimping Tips
03-8-3 APR 03 Engine - Oil Level Indicator Markings
03-7-1 APR 03 Body - Water Leak From Roof Opening Panel
03-6-11 MAR 03 Two Way Radio - Signal Loss/Static
03-2-4 FEB 03 Body - Driver Side Window Binds When Operated
02-23-7 NOV 02 Cooling System - Premium Gold Coolant Service Info
02-23-4 NOV 02 Engine Controls - DTC P1635 Set After PCM/IC Replacement
02-21-1 OCT 02 A/T - Torque Converter Access Plug Dislodges
02-21-11 OCT 02 Body - Cab Oscillation/Bounce at Highway Speeds
02-21-4 OCT 02 Body - Roof Ditch Material Cracking
02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check
02-20-8 OCT 02 A/C System - Diagnosis and Service Tips
02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling
02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers
02-12-1 JUN 02 A/C - White Flakes Coming From Vents
02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips
02-5-6 MAR 02 Sheet Metal (Primed) - Preparation Procedure
02-3-5 FEB 02 Tailgate - Squeaking/Binding Condition
02-4-5 FEB 02 Battery - Charging Tips and Guidelines
02-4-1 FEB 02 Idler Arm - Replacement Specifications
02-2-3 FEB 02 Engine - Aluminum Block/Head Machining
02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures
02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment
01-24-6 DEC 01 Engine - Oil System Priming Procedures
01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations
01-21-5 OCT 01 Engine - High Idle/Sticking Throttle
01-21-13 OCT 01 Ignition Switch - High Turning Effort/MIL ON/DTC's Set
01-20-5 OCT 01 Driveability - Vacuum Leak Detection
01-15-7 AUG 01 A/T - Fluid Application Charts
01-15-6 AUG 01 Heater Core - Repeated Failure
Old Sep 11, 2004 | 09:34 AM
jaymz's Avatar
????Moonroof Problems?????
Kinda wondering how many guys out there have the optional Lightning moonroof. Didn't know they were an option.
Makes me wonder about the validity of this list since no Lightnings have a factory moonroof...nor the gold coolant, nor the 4R70W tranny, yada, yada, yada.
Old Sep 11, 2004 | 10:11 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
very relevant numbers
Old Sep 11, 2004 | 11:48 AM
01 XLT Sport's Avatar
Re: ????Moonroof Problems?????
Originally posted by jaymz
...no Lightnings have a factory moonroof...nor the gold coolant
2003 & 2004 Lightnings have the gold coolant. I believe some eariler reg. F150's may have had the gold coolant. The TBS's may be listed under "Lightnings" but since a Lightning has many of the same components as the reg. F150 I think the TBS's include the reg. F150 in the listings...
